Lightweight Z18Xe
1943 replies to this topic
#1786 mini_mad69
mini_mad69
    Let future you worry about it
  • 5,417 posts
  • Local Club: urrrr no
Posted 21 March 2013 - 11:24 PM
Might not seem like much, but smaller parts being painted means big things and that re-assembly will start soon!!!
#1787 welshraider
welshraider
  • 61 posts
Posted 22 March 2013 - 08:08 AM
Looking good. I've got boxes of bits here that I have got to strip and reprint to get ready to go on mine.
#1788 mini_mad69
mini_mad69
  • 5,417 posts
Posted 24 March 2013 - 12:31 AM
Started to paint the bulkhead.
Painted my frame.
Cleaned the master/tower bolt.
Starting to come together now.
#1789 welshraider
welshraider
  • 61 posts
Posted 24 March 2013 - 01:28 AM
Looking good. U sticking with the same colour as last time.
Thought you were going for a gun metal finish??
#1790 mini_mad69
mini_mad69
  • 5,417 posts
Posted 24 March 2013 - 08:05 PM
Yeah went off the gun metal idea. I loved the colour it was, so going back on!
Started cleaning all the grot and rust off the floor.
Had to get loads of thick bitumen off the bulkhead which I added a few years ago in a bid to quieten it down inside. This has taken about 5 full days to remove.
Started painting it inside.
#1791 thelegg
thelegg
  • 608 posts
Posted 25 March 2013 - 07:17 PM
looking great :) again i tend to watch but not post any comments sorry, have you used a roller to paint the inside ?
#1792 welshraider
welshraider
  • 61 posts
Posted 25 March 2013 - 07:37 PM
What did house to get the bitumen off the metal work.. Got shed loads all over mine as you know. Any good chemicals or just a wire brush.
#1793 mini_mad69
mini_mad69
  • 5,417 posts
Posted 25 March 2013 - 09:48 PM
I used a heat gun and scraper, then a rag and thinners and then a wire brush on a grinder to finish it off.
#1794 mini_mad69
mini_mad69
  • 5,417 posts
Posted 29 April 2013 - 11:18 PM
9A33ADF0-3229-4DEC-B826-142EC15DE2BF-235
Undersealed the floor.
8A57CA96-EB8C-4071-937E-E47330661B2F-235
Finished painting the inside, everything not painted black will be body colour.
FA2C489A-AF99-45BC-92D3-5737CB8995A5-235
Rear end all done, refurbished rear arms, brakes, coilovers on. Rear valance on, new brake lines made and fitted. And carbon floor in. And you can see I've made a start with the fuel lines.
All sorted ready to take the engine.
Found one of my hubs had a crack in it, so sourced a new one, fitted new bearings, ball joints etc and rolled the car out......also pulled a face.
Bolted my sidemounts to the floor, but there seems to be a bit of flex when wobbling the seat, might weld some thin box section to the floor to stiffen it up.
Cleaned up my gearbox and fitted it with my lightened fly and organic competition clutch in between.
Getting closer now.
I've got a megasquirt ECU which I plan on using, anyone have any experience with the vaux coilpack? Mine has five wires coming from it, and am used to having 3.
#1795 leaky
leaky
  • 6,890 posts
Posted 02 May 2013 - 10:31 PM
Looking cool man! Will be great to see this back on the road!
#1796 HARBER07
HARBER07
  • 4,498 posts
  • Local Club: Naaa......
Posted 30 June 2013 - 09:09 AM
Pull your finger out mofo. Get it done for MITP :D
#1797 mini_mad69
mini_mad69
  • 5,417 posts
Posted 12 September 2013 - 09:15 PM
Have been fiddling recently, but hardly done anything.
I've been messing with the megasquirt ecu and decided too sell it, and use the money too buy a 1.6 8v engine too just chuck in standard too get the car on the road. I'm sick of it being in the garage. My thinking is, I don't know enough about megasquirt and my current z18xe engine. So will chuck in a more basic engine, do the basic wiring and get the car running. I have alot of parts from my mates mini "Vini" so hopefully once I get an engine it may go quite quickly.
Edited by mini_mad69, 12 September 2013 - 09:21 PM.
#1798 mini_mad69
mini_mad69
  • 5,417 posts
Posted 03 October 2013 - 07:43 PM
Brake lines all done! what a pain they were! With Willwood bias valve.
Finished welding these in and painted.
Holes I cut a while ago.
Welded in a strip of offcut.
Hole saw :D
Big hole!
Cup holder!
I'm waiting to hear back about a new engine to drop in. But will get my clutch plumbing done next time i'm up there. And maybe start some wiring.
#1799 mini_mad69
mini_mad69
  • 5,417 posts
Posted 06 October 2013 - 09:40 PM
I've my clutch lines, so once the engine runs the car should be able to drive!
So now all the steering, clutch, suspension, brakes, gear linkage, seats are all done and mounted. I just need it to run.
RE-did my gear linkage as the one I was using was a bit worn on the ball..null_zpsf6cf0d19.jpg
Then modified my handbrake for clearnace as it hit my gear selector, theres a pic of the button touching the selector somewhere in this thread.
So I undid the front bolt, bent it all back and welded in the mounting hole a bit higher up.
Needs too be ground back a bit, but thats its resting position, nice and accessible when the seats are in :)
I went to go buy an e16se engine, loom, ecu etc as a package to drop in. However when I got there the guy told me he hadn't taken it out of the yet, idiot! So had a good look over it and it seemed fine, so hopefully he'll take that out and I'll have that off him and get it running.
Edited by mini_mad69, 06 October 2013 - 09:44 PM.
#1800 mini_mad69
mini_mad69
  • 5,417 posts
Posted 13 October 2013 - 06:17 PM
Bought this.
Pulled out my z18xe, swapped over the lightweight flywheel, uprated clutch and f17 gearbox onto the e16se.
Standard manifolds squeeze in with standard manifolds.
z18xe fould the frame, nice neat 8v engine is narrow and fits :)
Oil pressure sender seems to foul on frame though.
Plugged the engine in, and pulled out the wires I need too wire into the mini. Yes, thats 4 wires to make it run....i hope.
Like it was meant to be there.
Hopefully I can make an exhaust next weekend, connect up a few wires and hope for a fire.
