Lightweight Z18Xe
1943 replies to this topic
#1726 mini_mad69
mini_mad69
    Let future you worry about it
  • 5,417 posts
  • Local Club: urrrr no
Posted 12 March 2012 - 07:06 PM
Spent more time on them, and got a pretty good finish on that one, now to do the others and paint them.
A panel off, and biiiiiiig hole.
Door off
Ummmmmm.............door :)
Patern
Patch welded in.
Just the same again on the other side, and the shock mount. And that looks to be most of the rust gone!!!
I need to do loads of grinding back, and start paint prep. :D
Not sure if im going to go for fixed a-panels or removable ones attached to the front end.
Edited by mini_mad69, 12 March 2012 - 07:07 PM.
#1727 mini_mad69
mini_mad69
  • 5,417 posts
Posted 13 March 2012 - 06:03 PM
Right, enough arsing about! I want all the welding finished by the end of the month.
#1728 mini_mad69
mini_mad69
  • 5,417 posts
Posted 17 March 2012 - 08:20 PM
Wanted a rolling shell today, but big holes slowed progress, so i chucked the front frame on so i can jack it up on that and weld up the hole where the blocks were.
Its just that bit of welding on the flitch, and offside shock mount and that should be all the rot gone.
Hopefully rust free rolling shell by the end of the month.
#1729 vini
vini
  • 316 posts
  • Local Club: no never again
Posted 17 March 2012 - 08:50 PM
glad to see im not the only one chasing the rot lol :gimme: Dean
#1730 mini_mad69
mini_mad69
  • 5,417 posts
Posted 17 March 2012 - 09:12 PM
Yeah, almost done now though :D
Then it's spanner time, which is what I actually like doing!
#1731 mini_mad69
mini_mad69
  • 5,417 posts
Posted 20 March 2012 - 09:43 PM
I got a new flitch panel and cut it down to what I needed. Unfortunatly my welder has gone wrong and won't penetrate or just plain work.
Bottom patch went in ok, but not great.
Fitted my rear beam back in so I could move it about and tidy up the garage.
It needs an engine to bring that front end down!
So I need to finish off the welding on the front right. and the shell is not far off ready for paint prep.
#1732 mini_mad69
mini_mad69
  • 5,417 posts
Posted 24 March 2012 - 12:14 AM
That should do.
#1733 mini_mad69
mini_mad69
  • 5,417 posts
Posted 25 March 2012 - 06:32 PM
Got my F13 box bolted up, only a couple of bolts to make sure it fits.
Rolled it out into the sunshine to turn it around.
And back in.
Engine looks huge compared to the car!
Hole
Sorted the welder and got the flitch in.
It had quite a bit of work done around here.
Cut out all the rot, but im not fixing it until I wire brush all the rust out and get some paint in there.
Ben
#1734 mini_mad69
mini_mad69
  • 5,417 posts
Posted 27 March 2012 - 04:08 PM
Got it roughly in
Sump sit's on the frame though :(
Might fit
#1735 HARBER07
HARBER07
  • 4,498 posts
  • Local Club: Naaa......
Posted 27 March 2012 - 05:13 PM
That will do man, just leave it like that. Less weight too.
#1736 mini_mad69
mini_mad69
  • 5,417 posts
Posted 27 March 2012 - 05:20 PM
yup..............done!
#1737 mini_mad69
mini_mad69
  • 5,417 posts
Posted 29 March 2012 - 06:35 PM
I got some engine mounts, not sure how good they will be, but will try them.
As you can see the sump is sitting on the frame, so I need to get hold of a steel one rather than the cast aluminium one I have now.
Got the shock welded up, so looooads of grinding back and pretty much all the rust is gone! Just need my gas bottle filled up so I can weld up some strengthening plates for the floor subframe mounts and cage mounts. But that can wait for a bit.
I don't know why, but i love the look of twin cam pulleys, kinda motivates me a bit.
Ben
#1738 The Matt
The Matt
  • 17,232 posts
  • Name: Matt
Posted 29 March 2012 - 07:10 PM
moved and title changed............that'll do pig? :ermm: :lol:
#1739 mini_mad69
mini_mad69
  • 5,417 posts
Posted 29 March 2012 - 07:14 PM
Yeah that'll do!!!
Officially not pulled along by a lump of pig iron now :D
#1740 mini_mad69
mini_mad69
  • 5,417 posts
Posted 26 May 2012 - 10:37 PM
Did alot of cutting out ready for some lighter parts.
Picked up some parts from a mate breaking his project.
Another allspeed subframe
MPI Tank
Fuel lines
Allspeed driveshafts
Diesel gearbox
Hydraulic clutch slave
vauxhall/mini loom
fibreglass rear valance
fibreglass boot floor
fibreglass front end
radiator
Some plumbing
Fuel pump
I have a carbon boot floor but it's not great so will probably use the fibreglass one.
Allspeed shafts
Allspeed frame/diesel box
Full boot
BMW full of mini bits.
This is the carbon boot floor, that I probably won't use.
I do like the carbon though :)
I'll get some better picture, and maybe some progress tomorrow :)
Ben
