That'll do.
Posted 21 February 2012 - 12:09 AM
Posted 22 February 2012 - 05:12 PM
Posted 22 February 2012 - 05:49 PM
Posted 23 February 2012 - 11:42 PM
Edited by mini_mad69, 23 February 2012 - 11:44 PM.
Posted 26 February 2012 - 12:32 AM
Edited by mini_mad69, 26 February 2012 - 12:33 AM.
Posted 26 February 2012 - 11:48 AM
Posted 27 February 2012 - 11:43 PM
Posted 28 February 2012 - 07:19 PM
dont the metro heads come with double v springs standard anyway?1380 build starts again tomorrow, engine will be dismantled and I will try to get it spinning over again. I will get it apart and inspect and measure the crank.
New spec for engine aswell.
1380 block
73.5mm powermax pistons
kent 286 cam
duplex timing gear
central oil pickup
1.5 rockers
998 gearbox
3.44 diff
Minisport inlet, (going to port match it to carb)
HIF44 with vizards modifications
Ram-air, air filter
Standard verto clutch system with new clutch plate
Facet fuel pump
Still undecided on head,
I have a head but I have no idea what it is, the valves look pretty big but the combustion chamber looks like it been home worked. On my current SPI block that im running.
I have an SPI cooper head. The issue with this is that it moves a little weirdly, it kinda sticks when on an engine, so ive never used it.
Im trying to get an MG metro head, and will then port match it and maybe double valve springs.
Going to try get the engine completed by the end of april.
For the car I have adjustable bottom arms and gax adjustable shocks.
Going to remove the amplifier that ran the subs and place the other one in the boot.
Will then sound proof and carpet the rear bench.
Posted 28 February 2012 - 07:54 PM
and i wasnt expecting that conversion, haha, vaux conversion sunds like a plan, gonna keep my eye on this threaddont the metro heads come with double v springs standard anyway?
1380 block
kent 286 cam
duplex timing gear
central oil pickup
1.5 rockers
998 gearbox
3.44 diff
Ram-air, air filter
Facet fuel pump
Posted 28 February 2012 - 08:17 PM
Posted 28 February 2012 - 11:29 PM
Posted 29 February 2012 - 07:00 PM
Posted 29 February 2012 - 07:28 PM
Posted 29 February 2012 - 11:37 PM
Posted 12 March 2012 - 12:46 AM
