Lightweight Z18Xe
1943 replies to this topic
#1561 arnie
arnie
  • 514 posts
Posted 04 May 2011 - 08:20 PM
mate would this help keep ur engine still. it worked great on my clubby. its forsale in classifieds if intrested pm me.
arnie.
  • Attached File  018.jpg   571.87K   9 downloads
#1562 mini_mad69
mini_mad69
    Let future you worry about it
  • 5,417 posts
  • Local Club: urrrr no
Posted 04 May 2011 - 08:27 PM
arnie.
Where does that go? :)
#1563 mini_mad69
mini_mad69
  • 5,417 posts
Posted 04 May 2011 - 08:28 PM
LOL - Rivi 2012 then??
I hope to have blown it up by then and moved on.
#1564 arnie
arnie
  • 514 posts
Posted 04 May 2011 - 08:33 PM
arnie.
it bolts to the bellhousing and the head bolt. then ur standard engine steady from the bulkhead bolts to this. i had it fitted because the thred had stripped in the head where the standard engine steady bolted. all i had to do was bolt the coil to the 2 clutch housing bolt holes.
#1565 mini_mad69
mini_mad69
  • 5,417 posts
Posted 04 May 2011 - 08:36 PM
arnie.
Theres nothing wrong with the standard steady that bolts to the block.
#1566 arnie
arnie
  • 514 posts
Posted 04 May 2011 - 08:43 PM
arnie.
just a thought mate thats all. this seemed to push the engine forward slightly then i adjusted the bottom gearbox steady and all was good.
keep up the good work.
#1567 GreaseMonkey
GreaseMonkey
    Has Ratchet, Will Make Noises
  • 3,663 posts
Posted 04 May 2011 - 09:09 PM
You having the oil drain going to where the fuel pump was? If you get stuck with finding one, buy a fuel pump blanking plate, drill a big hole in it and weld a pipe into it and you can angle it about to help etc
#1568 morley
morley
  • 903 posts
Posted 04 May 2011 - 09:24 PM
Thats what i'm doing, got mine from this guy.. bargain at £3 does them in stainless to :)
http://cgi.ebay.co.u...e=STRK:MEWNX:IT
#1569 mini_mad69
mini_mad69
  • 5,417 posts
Posted 04 May 2011 - 10:53 PM
I'm considering it, im just a little concerned that welding it will warp it and not seal, but i'm not sure.
I'm just being lazy, smiffys bits do a stainless one, im just waiting for them to relist it, as they are on holiday at the moment I think.
#1570 samsfern
samsfern
  • 5,243 posts
Posted 04 May 2011 - 11:02 PM
id have thought you may warp it if you do a constant weld, therefore you should be ok if you only do a little bit at a time, like a bit one side, then a bit the other side.
#1571 GreaseMonkey
GreaseMonkey
  • 3,663 posts
Posted 04 May 2011 - 11:03 PM
Ah yeah totally forgot that, saw it the other day
#1572 vini
vini
  • 316 posts
  • Local Club: no never again
Posted 05 May 2011 - 08:01 PM
just on the look out for the return plate that fits to the block.
got one here if u want it :thumbsup:
#1573 mini_mad69
mini_mad69
  • 5,417 posts
Posted 05 May 2011 - 09:07 PM
Do you? was that from the turbo engine that was in the hornet?
If so, yes I want it please.
Edited by mini_mad69, 05 May 2011 - 09:10 PM.
#1574 HARBER07
HARBER07
  • 4,498 posts
  • Local Club: Naaa......
Posted 07 May 2011 - 09:55 PM
To be fair that steady bracket will help as the loading is spread over several bolts, and not just relying on the one to hold it.
And good man for planning to blow it up... lmfao! :)
Bare sick
#1575 mini_mad69
mini_mad69
  • 5,417 posts
Posted 07 May 2011 - 11:16 PM
Bare sick
Well it's not broken yet.......
I'll be taking that solid steady out soon and fitting it to the gearbox. As the vibration it transfers into the cabin is mental.
I've also set a date for the completion of the turbo conversion : )
