Supercharged K20a2 Vtec - Race Spec
#106
Posted 02 May 2009 - 07:50 PM
#107
Posted 18 May 2009 - 05:41 PM
Made progress with N/S arch and have handed them to my friend Stuart Jago, who is a whiz with fibreglass and not too shabby at spray painting either.
Once the mdf was finished I had to fill all the holes and smooth the joins, I looked like casper when I had finished, will be totally worth it though. So here are a few snaps of the arches, some of the N/S and one of the two arches, they still had another round of filling and sanding after the photo before they went:
#108
Posted 18 May 2009 - 05:48 PM
#109
Posted 18 May 2009 - 05:58 PM
Some of you may have noticed a peice of ali at the rear of the tunnel with various sized rectangular and square holes in it, this is what I have called my gland plate. Another of my attempts to make the car as water tight as possible. The theory was to make rubber glands that fit snuggly around the brake lines, gear cables and handbrake cables. So as you can imagine this was a bit of a head scratcher for a while but has been sitting waiting to go together for a while now. The rubber was milled so that it has a shoulder that sits neatly in the holes.
The following sequence of photos show the block as drilled and then in situ, with and without the cable going through, I then fitted the handbrake cables in the same manner (will show these in a later post), it was not easy working it all out and the jigsaw of bolts and holes and threaded bar was 'interesting' to put together. It looks like it will work....bonus!!!
We start with a photo you will have seen before in a previous thread, remember it now??
Now the rubber block is being drilled, this one is for the gear cables, brake lines (footbrake and hydraulic handbrake) and clutch line:
The block post drilling and seperated:
The block offered up to the gland plate:
Now the block with the lines and cables running through:
#110
Posted 18 May 2009 - 06:11 PM
So I finally got my rear bulkhead fitted, wasnt the easiest of things to do as although the Z's bulkhead kit is a good fit to the inside of the shell I still needed to have bits welded to it so that is was a good fit all round.
The Dynamat has come in very handy indeed for my water tighting mission and I have to say that with that stuff stuck to the outer parts of the bulkhead it really makes a difference to the sound when you tap it - it is a dead sound, almost like tapping wood, sounds odd but the best thing I could come up with.
I had to make a decision to move forward with fitting the rear bulkhead even though I didnt have my fixing plates for the air scoops, that is another much longer thread and story.
Still a work in progress......
So here are a few shots of that lot going into place:
#111
Posted 18 May 2009 - 06:15 PM
The bolt for the N/S lever need to be as flush as you can make it so as to avoid collisionn with the main gear lever:
#112
Posted 18 May 2009 - 06:23 PM
Well as it was a nice day on saturday I wheeled the car out into the sun-sheeeiiiine (Liam Gallagher stylee):
And then I took it for a ride on a trailer and it came back looking like this, can you spot the difference????
It's kinda difficult from that angle.
Maybe this will help:
YEAH THATS RIGHT BABY - THE BEAST HAS AN ENGINE AGAIN - WOOOOO HOOOOOO
#113
Posted 18 May 2009 - 06:30 PM
Now I can tell you about the rest of the gland plate, couldnt do it earlier as it would have given the game away as the engine is in the photos.
So today saw me fittiing the glands for the handbrake cable, I will let the photos do the talking:
#114
Posted 18 May 2009 - 06:35 PM
#115
Posted 18 May 2009 - 06:42 PM
#116
Posted 18 May 2009 - 06:59 PM
#117
Posted 18 May 2009 - 09:06 PM
#118
Posted 18 May 2009 - 09:20 PM
#119
Posted 18 May 2009 - 09:30 PM
#120
Posted 18 May 2009 - 09:45 PM
AWSOME!!!!!!!!!!!!
