70mm Throttle Body Idling Issues - fixed.
AS some of you will remember I had bought a 70mm Throttle Body from Clockwise Motion, on the understanding that I wouldnt have to do anything to the throttle body to get good idling (as per the discussion with the vendor). Turns out that was a load of horsesh!t, the first time I tried it it idled at about 3k, then would hunt the revs once you'd given it some throttle.
So in an effort to fix the problem I went about lapping in the throttle plate to the throttle body, using really fine lapping compound that comes as a powder and mixed with thin oil. After hours of doing this I got the plate sitting sweet with virtually no light coming through, but when you breath tested it there were still streams of moisture breaking through and when I tried it on the car it would still hunt the revs and high idle - I am amazed as to how little amount of air is required for the engine to run.
A chat with one of our engineers at work brought up an 'Testors' enamel paint as a possible fix to the problem and is something that has been used in the US for years when trying to cure the very same problem. However in my tinternet exploration of Testors paint I stumbled across people using Dry Moly Lube as an alternative, might I add a much better alternative. Dry Moly Lube is, as it says, a dry lubricant but it has a bonding agent in it so when you spray it onto something it sticks like paint. So I went about masking up the throttle body so it would only spray on the required parts.
Once sprayed I light tested it and there was no light what so ever coming through, and a breath test showed no signs of moisture breaking through. It was time to mount it back on the car, I was feeling confident.....
I got it all on the car and started it up - it revved at 3K then hunted after blipping the throttle - aaaaaaaaaarrrggghhhhhhh
So here is where the investigation started,
Firstly I tried covering the hole that feeds the IACV (Idle Air Control Valve), this did not stop the engine, therefore this leaves two possible problems, its leaking past the throttle plate or theres another leak somewhere else.
Secondly I put my hand over the opening of the throttle body, this will tell whether there is a leak other than past the throttle plate......the engine still ran.......ah ha.......
Then I tried spraying some brake cleaner around the TBa nd inlet to find the leak with no joy, then I started to fumble around it with my hand to find I hadnt replaced the pipe that opens the bypass valve - TW4T.....
With the pipe clamped up properly I then started the engine and it now runs and idles..............thank god because it was really starting to feck me off.....
Here's a few photo's of the throttle body before I fitted it, so you can see what I did to it:
Firstly the dry moly:
Throttle body, the opposite side is similar but on the top side:
