Supercharged K20a2 Vtec - Race Spec
#871
Posted 23 April 2013 - 11:52 AM
Anyhooo, footage was taken and its up on YouTube:
#872
Posted 23 April 2013 - 01:44 PM
#873
Posted 23 April 2013 - 01:45 PM
#874
Posted 24 April 2013 - 03:44 PM
Good to see it on the track and you having fun. Sorry about the boot, at least ir wasn't the bonnet!
Track =
looks like you had good fun - Shame about the boot and the damage it caused though
Cheers Mike
Link to a video that shows all the participants of the Saturday morning session, a real varied bunch of cars:
#875
Posted 29 May 2013 - 06:39 AM
looks like you give the M5 a kicking! he! he! great.
#876
Posted 29 May 2013 - 09:53 AM
Thats was no ordinary M5 either, I took the owner for a few laps in mine and he was telling me that his was running 570hp, he ran out of runway at 172mph......
#877
Posted 29 May 2013 - 12:32 PM
was he very impressed with the mini?....
#878
Posted 30 May 2013 - 07:16 AM
Yes he was, especially the way that you can just gun the car and it sticks and goes, no tail swinging opposite locking.........
#879
Posted 25 June 2013 - 08:14 AM
In an attempt to get my noise levels down to get onto 98db track days I have added a removable extra silencer to my system now and I still have the ability to add my little bike silencer to mix as well should I require it. Also for the mini purists the exhaust comes out the correct side now (I personally like the centre exit look but its not an option with the diffuser).
So Last night Stevie G and myself set about making the new parts of the system and finally finished at 01:00 this morning which was good as there wasn't anything on the road when we went for the road test at unmentionable speeds.
So I removed all the wadding from the original silencer which was not in good shape as the outer skin of the silencer was colouring up with heat patches where the wadding had blown out of the exhaust. I have replaced the old wire wool/fibreglass wadding with Acoustafil High Temp wadding from PTR Exhausts. Its got a good rep and is a piece of p!ss to fit as it expands with heat so was jsut a case of taking out the old, wrapping the new around the perforated pipe and slotting it all back together. Anyone thinking of doing this will require 2 linear meters to fill a 6" silencer, width is dependent on size of silencer (I used 500mm wide for an 18" wide box).
Anyhooo, here are a few pictures of the work:
#880
Posted 25 June 2013 - 01:08 PM
For one track I go to I am to loud. So when going there I put a "Supertrap" on the end of my pipe.
#881
Posted 25 June 2013 - 03:32 PM
Personally I am not a fan of the Supertrap as they choke the system a bit too much for my liking especially in forced induction engines, I am not doubting their ability to reduce the decibels though as I know they do work. After seeing my manifold glowing bright red through the ceramic coating I figured that an absorption setup is the only way to silence the car, any form of restriction will just cause unwanted heat build up.
Hopefully with all this work should see the end of my black flag woes. As I said before if this still isnt enough I have the bike silencer that I know reduces the noise by approx 4db on a static (Stevie G if your reading this might need another stay making for the little silencer.....)
On a positive note I have to say that the whine of the charger never sounded so loud or so sweet......
#882
Posted 21 July 2013 - 09:40 AM
hi mate hows it going exhaust looks sexy does it work ok ? you going to coombe this year? trying to get mine put back together for it
#883
Posted 22 July 2013 - 08:27 AM
Hey Claudio, thanks...
I am still unsure as to its effectiveness but have a track day booked at Goodwood on the 12th Aug so will find out for sure there as they are super strict on noise levels.
Unsure about Combe this year as wont be in Miniworld stand again. Will tackle that one nearer the time.
#884
Posted 28 July 2013 - 08:29 AM
where your steering coloum bolts on, the tubular frame, is that a part of the zcars package or is it custom made?
#885
Posted 28 July 2013 - 05:45 PM
