Supercharged K20a2 Vtec - Race Spec
1102 replies to this topic
#376 Renessy
Renessy
  • 306 posts
  • Local Club: minisevenclub Holland
Posted 21 April 2010 - 02:24 PM
Everybody has some bad luck eventually in their build. Like you I have had many (waaaaayyyyy to many....)
Just get up, fix it and enjoy later!
Chin up!
#377 cptkirk
cptkirk
  • 1,799 posts
  • Local Club: B.M.C. + Chiminiclub
Posted 21 April 2010 - 03:45 PM
I have gotten so used to the setbacks now that when this happened I didnt even bat an eyelid over it, just took some photos, checked all was well around the area it fell into and then got on with fitting the locking strip for the windscreen and remaking my forward part of the raised tunnel.
A few emails this morning and a fix is all sorted, not too bothered as it will stop me running the car all the time for nor eason other than to run it.
Rene - Thanks for the booster though.........
#378 Renessy
Renessy
  • 306 posts
Posted 21 April 2010 - 04:14 PM
Ai' captn!
#379 cptkirk
cptkirk
  • 1,799 posts
Posted 22 April 2010 - 07:47 AM
Windscreen is in
Woo hoo I got the windscreen in with minimal assistance, I just needed my mate Stuarts locking strip insertion tool and while he was there he helped feed in the locking strip as I went round with the tool. Then fitted the wipers, which was amazingly easy.
I aim to get the charger off on the weekend ready to be fixed the following weekend.
Borrowed a carpet set of a mate (Kristian) who's mini should be ready fairly soon. So I am going to measure up and get a design laid out in CAD then fire that off to the carpet people.
My Whole reasoning for putting off having the doors hung is that once they are on it stops me from being able to work on the car in my little garage, which as you can imagine would make it quite restrictive and weather permitting.
Enough of my going on, here are a few pictures of the windscreen and wipers all in place (shouldnt need to use them much as its not exactly a wet weather car)
Finally one from the inside:
Edited by cptkirk, 22 April 2010 - 07:53 AM.
#380 mdickson
mdickson
  • 217 posts
  • Local Club: SMAC
Posted 23 April 2010 - 03:27 PM
Your car is looking good. Is it going to be ready for the Riv Run?
If not when can we expect to see/hear it in the flesh..
Good luck.
#381 granitdosa
granitdosa
    Starting My Mini Up
  • 1 posts
Posted 26 April 2010 - 05:58 PM
your arches are awsome! ;D
where did you buy them? or did you make them yourself?
MvH Chris
#382 andream88
andream88
  • 169 posts
Posted 26 April 2010 - 06:36 PM
Zcars arches ;D
#383 cptkirk
cptkirk
  • 1,799 posts
Posted 28 April 2010 - 08:11 AM
Good luck.
Thanks.
Cant guarantee any dates yet, especially now I have the charger to get fixed. As soon as I know when it will be ready and which show it will be at I will post it up on here.
your arches are awsome! :)
MvH Chris
Zcars arches :dontgetit:
Correct!
#384 LuckyThe1275
LuckyThe1275
  • 258 posts
  • Local Club: Not yet part of one!
Posted 28 April 2010 - 03:07 PM
Vroooom Vrooooooooooooooom.
That's all.
#385 cptkirk
cptkirk
  • 1,799 posts
Posted 28 April 2010 - 03:09 PM
Brilliant............
#386 LuckyThe1275
LuckyThe1275
  • 258 posts
Posted 03 May 2010 - 05:34 PM
I just got excited! This thing is amazing... The fabrication is phenomenal.
Ingenious and simple ideas just top it off! :tumble:
Good luck with getting it finished, getting close! :thumbsup:
Matt
Edited by LuckyThe1275, 03 May 2010 - 05:34 PM.
#387 cptkirk
cptkirk
  • 1,799 posts
Posted 10 May 2010 - 09:11 AM
EXPANSION TANK
An issue that had arisen along the way was a tiny pin hole in the weld of the expansion tank, just enough to bubble out when temps got high, coupled with the fact that I didnt have an easy way to drain excess coolant if I had over filled the system. So I had to remove the tank (which I dint think I would have to so didnt put electrical connectors to it or easy access to the bolts holding it in place - oops) to get the weld redone, thanks Barrie for sorting that for me.
I figured out a way to drain excess using a simple ball valve that I tee'd off from the future intercooler output from the expansion tank, maybe a sight gauge in the side would have been hadny I just couldnt find the bits to make one - I guess I just didnt try hard enough. Anyhooo - I put the hoses together for drain off and joined the expansion tank overflow/over pressure to the low pressure side of the ball valve.
here you go................
And a couple of pictures of the tank in place with the hoses all sorted:
#388 cptkirk
cptkirk
  • 1,799 posts
Posted 10 May 2010 - 09:49 AM
RAISED TUNNEL - GOING FORWARD
As with most projects things develop along the way, I originally put in place an extension forward of the raised tunnel, primarily as this is where I wanted to route my wiring and brake lines through to the rear of the car. The panels that I had put in place were OK but i felt they needed a bit of work as the wires down from the fuse board were visible from the seating position. So I have remade the panels with an extension upwards, unfortunately I havent got a cover done for it yet but its on the list of things to do.
So I am going to show a couple of before and afters ->>>>>>
One showing no extension:
A couple of the old style:
And now some of the new panels (excuse the poor quality photos - I only had the phone to hand):
#389 cptkirk
cptkirk
  • 1,799 posts
Posted 10 May 2010 - 11:07 AM
FRONT BULKHEAD CENTRE PLATE
Whilst i had the rasied tunnel extensions sprayed I also had the front bulkhead centre plate sprayed, I connected up the washer motor and I am glad to say it all works fine and its looks the dogs danglies to boot.
A few before and afters for you:
#390 james962
james962
  • 2,677 posts
Posted 10 May 2010 - 07:36 PM
Wow, exceptional work as always >_<
Thank you for sharing this whole project with us :lol:
James
