Anyone? nothing in my nut / bolt hoard seems to fit.
Non Genuine Track rod End
Edited by speedingorange, 24 October 2008 - 08:18 AM.
Posted 24 October 2008 - 08:17 AM
Posted 24 October 2008 - 08:22 AM
When giving the suspension on the car im building a quick once over i noticed some slack in the drivers side track rod end, Its non genuin, The slack was in the vertical pin to the steering arm. Unfortunately the thread in the nut had let go, anyone any ideas what thread it is on the pin? I thought it would be 3/8ths UNF but my die dosent seam to fit it. The outer size of the old nut was 11/16ths But it may well be metric
Posted 24 October 2008 - 08:40 AM
Edited by speedingorange, 24 October 2008 - 08:41 AM.
Posted 24 October 2008 - 09:57 AM
Posted 24 October 2008 - 10:31 AM
Edited by 998dave, 24 October 2008 - 10:32 AM.
Posted 24 October 2008 - 10:57 AM
Shouldn't be a problem really it's a fairly common size used on japanese cars and bikes. My concern is why it has metric threads, all the pattern parts i've fitted to minis so far have still used the correct sizes so i'm thinking you might have the wrong track rod end fitted, late metro or similar maybe. you'd be amazed how many people will fit parts just because "it looks near enough"And the mystery thread is....
M10 x 1.25 Fine.
What a silly size, got to find somewhere that stocks these now!
Posted 24 October 2008 - 11:37 AM
Posted 24 October 2008 - 12:10 PM
Posted 24 October 2008 - 02:18 PM
Posted 24 October 2008 - 02:42 PM
I was just suggesting.
Fair enough, a new nut it is, try minispares for it? you can probably pm [email protected] with the part number and ask him what nut you need.
Or find one on a Metro or something else.
Dave
Posted 24 October 2008 - 05:59 PM
track rod ends often have a whole range of threads, especially non-standard ones...My concern is why it has metric threads
Posted 16 January 2014 - 08:54 PM
Posted 16 January 2014 - 10:07 PM
I would be very seriously concerned about the strength and safety of what is clearly a bogus part, and demand a refund from the supplier. Track rod ends are relatively cheap. How do you value human lives, possibly your own? There are other dangers too, arising from the taper on a modern metric component probably not matching the Mini's steering arm.
Posted 16 January 2014 - 10:12 PM
Posted 16 January 2014 - 10:52 PM
