145/80r12 On A Mini
6 replies to this topic
#1 FrancisB
FrancisB
  • 10 posts
Posted 24 October 2008 - 04:54 AM
Hi,
I have to find snow tires for my 1993 Rover Mayfair. The car is running on 145/70r12 right now, but I can't find this size anywhere (for snow tires, I mean). I could however get some 145/80r12 pretty easily, and I was wondering if someone had some experience as to whether those tires will fit or not. At first sight it seems like it will clear the suspension and everything, but I'd still like to hear your thoughts.
Thank you,
Francis
Edited by FrancisB, 24 October 2008 - 04:57 AM.
#2 lrostoke
lrostoke
  • 6,923 posts
Posted 24 October 2008 - 05:48 AM
145 / 70 / 12 have a diameter of approx 20"
145 / 80 / 12 have a diameter of approx 21"
So only really 1/2" of clearance vertically difference, your suspension would have to be pretty low for them to rub. They shouldn't be any wider, just taller, I suspose you could get slightly more side wall movement which may mean they don't handle quite so well.
#3 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 24 October 2008 - 05:54 AM
145/80x12's will fit...
#4 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 24 October 2008 - 05:57 AM
145/80x12's will fit... but your leading edge on the front may just clip the arch...
#5 998dave
998dave
    998cc's Of Dave Goodness
  • 4,566 posts
  • Name: Dave
Posted 24 October 2008 - 07:30 AM
If the chance of clipping the arch is a problem you could limit the steering, like the sports packs, (not sure of their rolling radius).
D
#6 FrancisB
FrancisB
  • 10 posts
Posted 24 October 2008 - 12:12 PM
Thank you guys for your reply!
Unfortunately English is not my native language, and I still have trouble with some of the car-related expressions... Could you explain the meaning of "but your leading edge on the front may just clip the arch..."?
Thanks again!
Francis
#7 998dave
998dave
  • 4,566 posts
  • Name: Dave
Posted 24 October 2008 - 02:16 PM
No problem,
He means the front of the tyre may rub on the wheel arch when your turning tightly.
