Center Exit Exhaust
8 replies to this topic
#1 RedHot87
RedHot87
    Just On Tickover
  • 7 posts
  • Local Club: not yet but looking
Posted 23 October 2008 - 10:00 PM
Sorry if this question has been asked before but new to this forum business,
if i want to fit a center exit exhaust will i need to weld new hanging brackets, and how hard is it.
I will eventually be putting a straight through pipe on the old girl i take it that will need hanging brackets too??
thanks
RedHot
#2 Pooky
Pooky
  • 5,691 posts
Posted 24 October 2008 - 09:14 AM
When I fitted my Maniflow centre exit, it utilised the same bracket as the original at the front of the rear subframe. At the rear of the subframe there were two holes already present where I could put two cotton reel mounts for the exhaust bracket.
#3 998dave
998dave
    998cc's Of Dave Goodness
  • 4,566 posts
  • Name: Dave
Posted 24 October 2008 - 11:48 AM
Hi,
My centre exit exhaust had a different mounting system, sitting on top of two cotton reels, which then sit on top of one big C shaped bracket:
I had to drill holes in the horizontal part of the subframe to put the nuts and bolts through, using nyloc nuts to minimise possibility of it coming undone.
Which then placed the exhaust around here:
And a pair of valence hugging foglight finished it off nicely.
Edited by 998dave, 24 October 2008 - 11:50 AM.
#4 captainjack15
captainjack15
  • 3,925 posts
Posted 24 October 2008 - 01:05 PM
Yeah I have the same as above.
#5 RedHot87
RedHot87
    Just On Tickover
  • 7 posts
Posted 24 October 2008 - 02:14 PM
nice one, gunna look into it at the weekend and when its done i post up some pictures
cheers
RedHot
#6 MiniMonty
MiniMonty
  • 1,802 posts
Posted 26 October 2008 - 12:30 AM
I've got a Maniflow centre exit with straight through pipe hanging around my shed - is there any benefit to fitting it
to my standard 998 ?
Can't tell you why but I just like the idea of a centre exit - but will it decrease power as it increases noise ?
Best wishes
Monty
#7 captainjack15
captainjack15
  • 3,925 posts
Posted 26 October 2008 - 09:52 AM
Well if it is too big then back pressure will be lost and will therefore you will lose power, but with a straight through you get a loverly noise :(
Someone else shall be able to add more to what I have said :- But I like to help as mush as possible :(
#8 Broomer
Broomer
  • 1,771 posts
Posted 26 October 2008 - 09:55 AM
My centre exit is held on by two big stainless bolts going through the rear subframe on the same kind of hanger on the maniflow system pictured above..
#9 998dave
998dave
  • 4,566 posts
  • Name: Dave
Posted 26 October 2008 - 11:06 AM
depends what pipe you get, if you get a silly big DTM then probably, if you stick with a twin box RC40 style system, (you can buy them in centre exit guise), then you should be okay.
I like the centre exit look, it's all about symmetry, hence the twin fogs, and fuel fillers, etc. Also the mk1 no. plate light tidies up the rear end!
D
