SPI Cooper problems
#16
Posted 18 July 2005 - 11:20 AM
#17
Posted 18 July 2005 - 12:11 PM
#18
Posted 18 July 2005 - 12:21 PM
Ok, so the last bit you don't have to do, but it might help?!
#19
Posted 18 July 2005 - 12:34 PM
#20
Posted 18 July 2005 - 12:38 PM
#21
Posted 18 July 2005 - 08:57 PM
#22
Posted 18 July 2005 - 09:20 PM
#24
Posted 18 July 2005 - 09:48 PM
#25
Posted 18 October 2007 - 10:31 AM
Steve
Edited by SpecialK, 18 October 2007 - 10:31 AM.
#26
Posted 18 October 2007 - 10:36 AM
Hi, could someone please clarify how you reset the ECU for me? and is it safe to do so
Steve
Turn the ignition on, don't start the engine, and stamp the accelerator 10 times. Then turn off the ignition.
Perfectly safe (I believe it floods the engine so when you try to start it again the ECU resets).
#27
Posted 18 October 2007 - 05:37 PM
The ONLY way to reset the ECU is by connecting a diagnostic service tool!!
Depressing the accelerator pedal with the engine not running, but ignition on will never flood the engine, the injector is not operating!
#28
Posted 28 October 2007 - 06:03 PM
Wow, that is a wonerfull ritual, where did you learn that?
Hmmmmm, so there will be no point doing it then!!! LOL ah well back to the garage
#29
Posted 28 October 2007 - 06:25 PM
if you have a problem have a look here and discuss it
http://www.theminifo...p?showforum=140
#30
Posted 28 October 2007 - 06:57 PM
Replace the Vac pipes with new ones, as even the smallest split can cause a lot of problems - also check that the fuel trap isn't cracked.
Another thing to check if it's repeadedly revving up and down, but in a steady rythmm, is to check that you either haven't got the throttle cable too tight, keeping it open when your foot isn't even on the pedal, or that the switch on the accelerator pedal is working properly
If you try to just rev the engine from inside the engine-bay, it'll just rev up, then drop back down to idle every few moments. This is because it knows that the accelerator pedal isn't depressed - why it does this, I couldn't tell you, but it's something which can happen if the cable has been adjusted too tightly
