Minispares Electric Window/alarm/central Locking Kits
16 replies to this topic
#1 Bevan
Bevan
  • 736 posts
  • Local Club: On the search!
Posted 20 October 2008 - 04:42 PM
My birthday is comming up soon and will be asking the folks for new electric for the mini.
I have been reading thru the minispares website and found the remote central locking, electric window and alarm/immobiliser kits.
Has anyone got any of these kits?
The Keyless Entry + Alarm says it can be used with Door Central Locking kit which is what I want, but does their electric window kit work with the central locking and alarm?
I found on Moss's website they have a power moduel where if the windows are down when you alarm the car it will close the windows for you, does minispares have anything similar as I have not been able to find anything on their website.
p.s links are showing random pages for some reason
Many thanks in advance
Edited by Bevan, 20 October 2008 - 04:43 PM.
#2 screech
screech
  • 3,136 posts
  • Local Club: Bognor rock ya mini & WSMOC
Posted 20 October 2008 - 05:36 PM
The electric windows, central locking etc are all the same kits sold by moss, mini spares mini speed etc.
When i was installing my system i spoke to them and they informed me that they supply these kits to all the mini specialists, so that alarm from mini-spares and the power window modual from moss should work together, might be worth calling mini-spares to see if he can get the whole lot in.
Edited by screech, 29 May 2018 - 11:21 AM.
#3 Bevan
Bevan
  • 736 posts
Posted 20 October 2008 - 07:20 PM
nice one, that makes things even better as minispares are cheaper then moss!
#4 roofless
roofless
    Sticker Pimp
  • 7,215 posts
  • Local Club: central minis
Posted 20 October 2008 - 07:39 PM
yes - sort of - got both central locking and 4 x electric windows on mine and they work with auto-closure on the right alarm system. I'm not using the moss alarm but an aftermarket one with the correct modules.
soon to be replaced though as it has become problematic recently.
in answer properly though - they dont all work together seamlessly - they need fiddlin and twaddlin.
#5 norwegianminiman
norwegianminiman
  • 323 posts
  • Local Club: norwegian mini cooper club
Posted 20 October 2008 - 08:27 PM
any idea how much work it would be to swap a rover alarm for these?
#6 v21ash
v21ash
  • 421 posts
  • Local Club: HumbersideMiniClub.co.uk
Posted 20 October 2008 - 08:46 PM
I got both kit's but my locking is done through the factory alarm/keyfob, can't remember who i got my module off but mini trailers do the same one
http://www.minitrail...com/central.htm
I've also got the window rollup module fitted to my factory alarm but again i can't remember where i got it from (it was 12 years ago).
#7 Elisha-The-Cooper
Elisha-The-Cooper
  • 1,077 posts
  • Local Club: leeds m.o.c
Posted 20 October 2008 - 09:53 PM
wouldnt use mini trailers website, they dont take the money or reply, but minispares do the kits and there very good and quite easyy to fit
x
#8 AzMaN
AzMaN
  • 457 posts
  • Local Club: BMC
Posted 20 October 2008 - 10:16 PM
on the same kida subject, where did you put the hole to run the wiring from the door into the car (pics would be nice)
#9 DFulton
DFulton
  • 158 posts
Posted 20 October 2008 - 10:35 PM
Wouldn't have thought it would be too hard, but you don't need to. They do another c/locking kit that can be integrated with the rover alarm. The rover unit is capable of running central locking and the two can be wired together. I've had this on my MPI for the last year now and it all runs off the original remote. I get both alarm and locks simultaneously (still winding my windows by hand).
#10 DFulton
DFulton
  • 158 posts
Posted 20 October 2008 - 10:37 PM
Don't have a photo I'm afraid, but the kit I got (from moss) told me roughly where to drill. I put it a little bit below the upper hinge. I had tons of spare cable, you just need to be a bit careful that it doesn't get in the way of the window mechanism (lots of ties are useful).
#11 norwegianminiman
norwegianminiman
  • 323 posts
Posted 21 October 2008 - 06:56 AM
where may one aquire one of these? links would be nice
#12 v21ash
v21ash
  • 421 posts
Posted 21 October 2008 - 08:45 AM
x
to be honest i wouldn't use mini trailers either, but it was the only link i could find to the factory upgrade kit.
The minispares alarm modules are not the same!!! they are a module that is seperate to the alarm so it runs from a seperate key fob.
There's one above, although i wouldn't buy from them, it gives you an idea of what to look for.
Edited by v21ash, 21 October 2008 - 08:49 AM.
#13 DFulton
DFulton
  • 158 posts
Posted 25 October 2008 - 03:49 PM
Sorry not to get back sooner - been on holiday.
I've also checked and I apologise - it wasn't Moss, it was Mini Spares I got mine from. They do two kits. One for the older cars, where you can then also get the keyless entry kit, which comes with its own fobs and another set is for the MPis. The second is the one that I have - MSSK2004 is the key-controlled central locking (£61.69 inc VAT) and then you buy MSSK2006 (£28.20) to get the additional wiring to plug into the Rover module. It then all runs on the existing Rover remote, alarm and locks at the same time - nice.
It wasn't too hard to fit. It's a little fiddly to get the locking mechanism right (the travel is only *just* enough in each direction) so you need to spend a bit of time carefully measuring up before you drill and bolt into the existing lock lever, but mine's survived about a year of bouncing around the road now. The wiring is straightforward, except for the step that said "find a convenient 12v power source". I eventually found a bit of connector block on the back of the stereo and decided to use that rather than risk damaging the supply to something more critical. Other than that, and finding somewhere to mount the relay, it's trivial to fit and came with tons of spare cable, so you could be pretty flexible as to where you put it.
Edited by DFulton, 25 October 2008 - 03:49 PM.
#14 baggy33minis
baggy33minis
  • 367 posts
  • Local Club: none at the moment
Posted 25 October 2008 - 08:24 PM
A cheap solution to power windows perhaps.
www.zippyvideos.com/3214710857409146/power_windows
#15 Elisha-The-Cooper
Elisha-The-Cooper
  • 1,077 posts
Posted 26 October 2008 - 08:09 PM
lol :D
