Engine Mounts Solid Or Poly
11 replies to this topic
#1 foodboy
foodboy
  • 149 posts
Posted 20 October 2008 - 09:22 AM
hello there, not sure what engine mounts to use, poly or solid??? im not that botherd about the noise.
please help
Bn
#2 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 20 October 2008 - 09:24 AM
neither... use standard ones on anything but an outright competition vehicle.
#3 foodboy
foodboy
  • 149 posts
Posted 20 October 2008 - 09:37 AM
whys that then?
Bn
#4 markaboot
markaboot
  • 723 posts
Posted 20 October 2008 - 10:02 AM
dont flip fronts have to be solid mount?
#5 Jammy
Jammy
  • 25,397 posts
Posted 20 October 2008 - 10:12 AM
The teardrop mounts do. But then thats nothing to do with the engine mounts.
I'm with Guessworks. Standard rubber mounts are fine. Poly and solid engine mounts just transfer unnecessary amounts of vibration through other components.
#6 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 20 October 2008 - 10:19 AM
Flip fronts need solid subframe mounts not engine mounts, two completely different things...
If you are talking about subframe mounts, then solid every time...
Problem with poly, same goes for subframe, suspension and engine bushes/mounts, is that is does not degrade over time like rubber, they fail/split with no warning...
Solidly mounting an engine puts immense strain on both the engine and subframe, and hence why should only be used on competition vehicles, where they are regularly maintained, stripped down and inspected.
Poly, in my view, are a complete waste of money.
If an engine is fully mounted with good bushes on top and bottom engine steadies, then there is absolutely no reason why std engine mounts are not up to the job. Just don't buy cheap import knock offs.
#7 foodboy
foodboy
  • 149 posts
Posted 20 October 2008 - 10:20 AM
but dont you get more power to the wheels with the engine with poly and solit mounts?
Bn
Edited by foodboy, 20 October 2008 - 10:21 AM.
#8 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 20 October 2008 - 10:25 AM
Bn
Err.. No, how can something which is externally mounted to an engine which is passive in the terms of does nothing but hold the unit in place affect the internal dynamics of an engine ???
#9 foodboy
foodboy
  • 149 posts
Posted 20 October 2008 - 10:44 AM
Bn
It has nothing to do with the internal dynamics of the engine, but contributes to energy transfer. As you accelerate with standard bushes the engine moves/ rocks this is energy being waisted through the bushes, with solid mounts less energy is wasted through the bushes as the engine cannot rock. Isnt that why they have solit engine mounts and solit engine stays????
#10 T.Harper
T.Harper
  • 714 posts
Posted 20 October 2008 - 10:47 AM
Bn
I think the result you'll feel is more response, not anymore power, however whether you notice this is arguable. Rubber :shifty:
#11 foodboy
foodboy
  • 149 posts
Posted 20 October 2008 - 10:58 AM
Bn
ok yes response of the engine would be quicker.
Bn
#12 Jammy
Jammy
  • 25,397 posts
Posted 20 October 2008 - 11:04 AM
The rocking of the engine makes an infinitesimally small difference to the output of the engine.
As Guessworks says, with two standard rubber engine mounts, the gearbox steady mount, and the engine steady mount, you really shouldn't get much, if any, movement from the engine anyway.
