Converting A Turbo Charger Into A Supercharger
24 replies to this topic
#16 Vipernoir
Vipernoir
  • 782 posts
  • Local Club: Minis Unlimited
Posted 24 October 2008 - 12:44 PM
ring gear will be about 20-24" but thats diameter not circumference, the gear would need to be 1/24th the circumference for the right rpm.
Errr....
Circumference is a derivative of diameter. The pulley will need to be 1/24th of whatever dimension you choose to measure on the flywheel.
Either way, the small pulley will only be about an inch across.
140,000 rpm at 7000rpm is pointless - you need to achieve max boost lower down the rev range or it will be a topend screaming monster that is nigh on undriveable.
#17 norwegianminiman
norwegianminiman
  • 323 posts
  • Local Club: norwegian mini cooper club
Posted 24 October 2008 - 05:40 PM
norwegianminiman is correct...
yey someone agrees with me^^
did a wee bit of calculating:
assuming one wants the charger going at 140000RPM at 3500RPM, and that the flywheel if 20"diameter...
then having the flywheel (20") driving a 2" pully on the intermediate shaft, then a 4" pully on there driving a 1" pully on the charger...
then... 3500RPM*(20"/2")=35000RPM on the intermediate shaft, and 35000RPM*(4"/1")=140000RPM on the charger... my head hurts now, hate digging out knowlage I've only used once before :D
#18 davethemini1293
davethemini1293
  • 105 posts
Posted 10 June 2010 - 07:47 PM
ok thread dig up,
but did you ever get anywhere with this???
im collecting parts atm,
i've already got a t34 cossie turbo
and abilty to make pulley's etc,
i like the idea of running it direct from the flywheel,
any new thoughts?
#19 davethemini1293
davethemini1293
  • 105 posts
Posted 11 June 2010 - 09:21 AM
anyone??
#20 davethemini1293
davethemini1293
  • 105 posts
Posted 11 June 2010 - 08:16 PM
serious?
no body has any input atall????
this could be a Very cheap way to forced induction....
OR very expensive.....
#21 Shaz_mini_Beast
Shaz_mini_Beast
  • 86 posts
  • Local Club: North West Mini Club
Posted 12 June 2010 - 02:19 PM
no he's not gone down that road, i know as he's building my turbo engine atm and my mini is in his garage lol.
#22 mini.cooper998
mini.cooper998
  • 685 posts
  • Local Club: looking
Posted 12 June 2010 - 06:03 PM
shaz is right i ended up going the roots way very similar to johnnysti on here. once i get shaz's turbo built up will be starting back on the track car build and the blow through eaton m45 setup. cant wait now
Andy
#23 Shaz_mini_Beast
Shaz_mini_Beast
  • 86 posts
Posted 13 June 2010 - 05:01 PM
you'll be glad to kno andy ive ordered my boost pipes, megajolt, and filters >_< proper big hit on it. sorry i never came round this weekend been a bit mad. ive got my poppers, lead replacement, pointless turbo module and boost controller sat in my bedroom ready to go on. :shifty:
#24 Wil_h
Wil_h
  • 3,244 posts
Posted 14 June 2010 - 11:00 AM
I think most of the problems with this idea are apparent in this thread and it's self expanitory why this project never went any further.
Basically of you want a belt driven centrifugal charger then buy a rotrex.
#25 NDT
NDT
  • 181 posts
Posted 15 June 2010 - 04:13 PM
Agreed.
Belt driven centrifugal blowers are not a great idea - boost goes up non-linearly with speed.
The best way to engineer this would be to get compressor maps for the different compressors and work out the thermodynamics from there.
IIRC things like the turbo technics supercharger had an oversized compressor compared to a turbo, so that there was some meaningful boost at lower rpm.
Then to stop overboost at high rpm, rather than use a blow off valve (which would work but would waste a lot of energy), sized the inlet to the compressor to 'choke' the flow.
A positive displacement blower would be better - or a Messerschmidt style centrifugal blower with a slipping clutch... buth that's not easy to set up at home...
    Google (1)
