Torque Settings (reformatted)
#16
Posted 12 June 2012 - 10:48 PM
#17
Posted 06 August 2012 - 04:03 PM
Joey - Another one that's missing, refer to Haynes.
#18
Posted 23 September 2013 - 01:54 PM
Edited by Miniac86, 09 January 2014 - 05:57 PM.
#19
Posted 05 January 2014 - 10:54 AM
I think later boxes these are secured with roll pins but mine is bolts and lock nuts.
Thanks Dave
#20
Posted 05 January 2014 - 03:46 PM
No there isn't, and they really don't need to be done that tight, I use a small ratchet spanner to do them up... probably no longer than 4 inches in length and they are only done spanner tight at that, but I do loctite them in...
#21
Posted 05 January 2014 - 05:02 PM
243? or something stronger?
Posted 05 January 2014 - 07:08 PM
I use 270 on anything inside the gearbox.
#23
Posted 05 January 2014 - 07:37 PM
thanks
#24
Posted 10 September 2014 - 10:30 AM
Maybe helful which Bolts and nuts you need for the Mini. Sorry it is a mix of Englisch and German.
I have collected thes data from different sources and own findings.
As Newtonmeter is internationally more and more used here some help:
1 Nm = 0.101972 kpm
1 kpm = 9.80665 Nm
1 lbft = 1.355818 NM
1 NM = 0.737562 lbft
Edited by Alpenflitzer, 10 September 2014 - 11:30 AM.
#25
Posted 28 October 2014 - 04:28 PM
#26
Posted 15 March 2016 - 11:40 PM
Oil filter centre bolt AP2 Automatic = 8 to 10ft-lbf
#27
Posted 02 September 2016 - 03:58 AM
#28
Posted 23 September 2016 - 06:53 PM
You can verify if they are the correct values, or errors in general?
https://1drv.ms/b/s!AHKor3_6E_C1iG4
Thank you all :)
Gero
#29
Posted 28 November 2016 - 12:20 PM
Following up on ths old thread, I wanted a ready reconner for general purpose nuts & bolts based on the head/spanner size. Lifting the torque settings from the MPI workshop manual for metric 8.8 and UNF Grade 5 tensile strength and reworking...
Nut/Bolt Jaw Spanner Torque mm Nm ft-lb UNF 1/4 UNF 11.11 7/16 AF 9 6 5/16 UNF 12.7 1/2 AF 25 18 3/8 UNF 14.29 9/16 AF 40 29 7/16 UNF (bolt) 15.88 5/8 AF 75 55 7/16 UNF (nut) 17.46 11/16 AF 75 55 1/2 UNF 19.05 3/4 AF 90 66 9/16 UNF (bolt) 20.64 13/16 AF 135 99 Metric M5 8 8mm M6 10 10mm 10 7 M8 13 13mm 25 18 M10 17 17mm 45 33 M12 19 19mm 80 59
Hope this is useful
Edited by Deeppockets, 28 November 2016 - 02:22 PM.
#30
Posted 05 December 2016 - 08:30 PM
Nut/Bolt Jaw Spanner Torque mm Nm ft-lb UNF 1/4 UNF 11.11 7/16 AF 9 6 5/16 UNF 12.7 1/2 AF 25 18 3/8 UNF 14.29 9/16 AF 40 29 7/16 UNF (bolt) 15.88 5/8 AF 75 55 7/16 UNF (nut) 17.46 11/16 AF 75 55 1/2 UNF 19.05 3/4 AF 90 66 9/16 UNF (bolt) 20.64 13/16 AF 135 99 Metric M5 8 8mm M6 10 10mm 10 7 M8 13 13mm 25 18 M10 17 17mm 45 33 M12 19 19mm 80 59Hope this is useful
It could have been, however as you decided to compile your chart based on the head size it isn't that useful at all it should be based on the thread and shank diameter, the fixing material, the thread manufacturing method, any heat treatment processes and the same for the threaded hole it fits into as these are all important and WILL have a detrimental effect on the torque wrench figure used.
