Gear Linkage Rod Roll Pin
41 replies to this topic
#1 Brams96
Brams96
  • 2,308 posts
Posted 16 October 2008 - 03:46 PM
Hi all, this might have come up before but I cant seem to find it with a search.
Can anyone tell me the easiest way to remove the little roll pin connecting from the back of the engine to the gear selector rod?? I have tried a few things like hitting it with a hammer & punch but it doesn't want to budge. Do I need a tool of some sort or a bigger hammer :) ?
#2 Retro_10s
Retro_10s
    Moderator
  • 10,186 posts
Posted 16 October 2008 - 03:48 PM
You're pretty much going to have to just keep on hitting it with a hammer, though I've found some heat has helped in the past and some PlusGas/WD40.
#3 Asphalt
Asphalt
  • 2,173 posts
Posted 16 October 2008 - 04:03 PM
Use 'something' flat without a point in the pin's (outer) diameter and drive it out using a hammer.
(Anything pointed makes the pin go stuck very tight!)
Lubrication, as mentioned, helps it.
Hope this is of some help :)
Cheers,
Jan
#4 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,840 posts
Posted 16 October 2008 - 04:06 PM
also put the gearbox into reverse, makes for a better angle of attack at the roll pin nearest the box...
#5 TheRestorer
TheRestorer
  • 69 posts
  • Local Club: My club!
Posted 16 October 2008 - 04:13 PM
Just the hammer and a roll pin punch im afraid mate. 3/16" roll pin punch is ideal.
The roll pin might put up abit of a fight but just keep tapping away.
#6 mini1976
mini1976
  • 408 posts
Posted 16 October 2008 - 04:22 PM
Personally, when I had got the roll pin out I replaced it with a stainless steel bolt with nyloc nut of an apropriate size. So the secont time I had to take my engine out it took about a minute to take out.
#7 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,840 posts
Posted 16 October 2008 - 04:35 PM
can you get it into all gears with the bolt ?
#8 lozp
lozp
  • 27 posts
Posted 16 October 2008 - 05:08 PM
hi
sorry to hijack this thread but ime having the same problem aswell, i managed to budge the horizontall pin (nearest the gearbox) about 3mm but then the punch sheared and a small bit has got stuck in the inside of the pin and now it wont move at all ARRRGH. i heard that the verticle pin is even harder to move but i think this is my only option, how much does a bit of heat help???
#9 scotchmist
scotchmist
  • 92 posts
  • Local Club: Minisunlimited
While were on the subject, does any one know of a good way of getting the roll pin back in?
#10 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,840 posts
Posted 16 October 2008 - 05:15 PM
Roll pin back in is an easy one...
Use a pump wrench and squeeze it in...
like these Posted Image
#11 Brams96
Brams96
  • 2,308 posts
Posted 16 October 2008 - 07:39 PM
Cheers for all the info guys, I'll give it a go tomorrow.
#12 Monstrous
Monstrous
  • 889 posts
Posted 16 October 2008 - 08:58 PM
I've done this 4 or 5 times now and ive found by far the easiest way is to use a precision screwdriver like the one pictured below
if you get the right size one, the black pointy but will slide through the role pin, and the shoulder of the silver bit will sit on the roll pin itself, this keeps it aligned and also doesn't damage the roll pin. Couple of sharp blows and it's out...
#13 mini1976
mini1976
  • 408 posts
Posted 16 October 2008 - 09:26 PM
Yeah no problem at all. To start with I just had the stainless bolt dropped in with no nut. The only way you could get it in/out is in revers I think (it a while since ive had it out) anyway since then ive machined a stainless clevis pin that again just drops in and is a nice snug fit. never had any problems with it and is so quick to take out and put back in. I can get you a photo if you like.
#14 Brams96
Brams96
  • 2,308 posts
Posted 17 October 2008 - 07:47 PM
Wayhaey you were right, HIT IT HARDER! After using the correct punch and a bigger hammer and selecting reverse (cheers GW) it came out in seconds. I've got the engine out and half stripped already, now I just have to split the block and G-box and crack on.
Cheers All
:thumbsup:
#15 jimmyH
jimmyH
  • 260 posts
Posted 13 July 2015 - 10:33 AM
Well here we have a thread resurrection of note!
Currently working on the final bits and bobs before i take out my engine, i have been stumped by my gear selector roll pin (nearest the box) I have the correct punch, good hammer ect. However there is nowhere for the pin to go/exit the rod. The angle of the rod means the pin would wedge against the GB/ rod above. Rather than the pin being aligned from one side to the other, its aligned up and down.
I am trying in third gear, advice given at the time.
Would reverse give the pin room to move, or is something not quite right ?
Any ideas ?
