Hey everyone
I have a 1275 metro engine in my mini and recently for my birthday my best mate very kindly bought me the smiths dual water temp and oil pressure gauge which you can see below.
http://www.minisport...30164-B078.html
The water temp is not a problem but dont know much about the oil pressure and how to hook it up. I think its a mechanical gauge so does that mean i need to run a capillary tube up to the gauge? I think i found it on mini sport, is this the tube i need?
http://www.minisport...o_LMA003-4.html
If so where do i hook the other end up to on the engine?
All advice welcome. Cheers
Dave
How To Fit A Oil Pressure Gauge?
BigDave99
, Oct 11 2008 11:02 AM
3 replies to this topic
Posted 11 October 2008 - 11:02 AM
Posted 11 October 2008 - 11:06 AM
you will all so need this
http://www.minisport...fo_LMAAC16.html
just unscrew you idiot red light sender screw the T in and screw your idiot light sender back in one side and the gauge sender in the other
the low oil pressure sender (idiot light) can be found on the far left of the engine block above the starter
Posted 11 October 2008 - 12:21 PM
The water portion of the gauge may appear easy but there are a couple of things you may want to do or need.
See Mini Spares, look for item #TE5. You MAY need this if you find the expansion bulb on the temp gauge capillary tube extends too deep in the head casting. These adapters are not expensive.
DO NOT cut or think of cutting the water temp capillary tube... EVER. Make sure when installing the capillary tube that you place some coils in its length to absorb vibrations from the engine.
Lastly, apply anti-seize compound to the sender threads before putting the expansion bulb in the head (or adapter). This will save you a lot of grief later.
Posted 11 October 2008 - 01:53 PM
