there is a way; if you join the viewty forum they do have a section on it.
http://www.mygreatph...forum/index.phpits a bit involved.. i'll copy an paste.
Method 1
From MyGreatPhone.com
Jump to: navigation, search
SUPPORTED MODELS:
KU800 2007 VERSIONS !!!/U990/KU990/KU380/CU400/CU405/CU500/CU500V/CU320/TU500/TU550/MU500/MU550
1. DOWNLOAD LGMDP AND MAKE BACKUP OF NV (USE WINDOWS ENABLE SOFT TO SELECT NV BACKUP ONLY AND ENABLE START AFTER THAT YOU CAN GET FROM HERE
http://rapidshare.co...231/wm.rar.html2. DOWNLOAD MTTY FROM
http://rapidshare.co...2/mtty.exe.html3. OPEN MTTY AND SELECT PORT ON WHICH MODEM USB PORT OF PHONE IS ASSIGNED
4. AFTER WINDOW OPENS TYPE 'AT%SWV' (WITHOUT QUOTES) AND PRESS ENTER. IF YOU GET REPLY ALL IS OK
4. TYPE 'AT%IDDE' (WITHOUT QUOTES) AND PRESS ENTER. IF YOU GET IDDE OK MEAN PHONE SUCCESFULLY UNLOCK
5. DON'T POWER OFF PHONE. USE LGMDP TO RESTORE NV.
6. ENJOY A SUCCESSFULLY UNLOCK PHONE.
P.S: CAN AFTER 'AT%IMEI=WANTED IMEI' TO CHANGE IMEI
THIS SOLUTION WONT WORK ON KU580 SEMC A2 PLATFORM, KS20, KU730, KU950 AND PROBABLY KU250 ASWELL.
LGMDP AVAILABLE HERE :
This is LGMDP 1.5 Build 12.10 Program.
- LGMDP_OPEN - LGMDP_US - LGMDP_EURO - LGMDP_H3G
Thanks to hack3r2k form FuriousTeam
NB. You may need to obtain new IMEI and Bluetooth address' after using this method.
Retrieved from "
http://www.mygreatph...title=Method_1"
