This is how i built mine.
First covered the whole right hand side area of the boot with black bin liners and held in place with double sided tape. Then I took a mold of the area by sticking strips of glass fibre matting to the plastic. Molded the bottom and sides but not the top (because the matting just fell down).
For the top once the glass had cured i just placed a flat bit across the top and fixed it there with resin.
(dont have any images of this bit sorry, But it was VERY messy and took 3 go's to get it right!)
The finished Fiberglass enclosure looks like this:
The enclosure was then coated on the inside with 3 layers of Noise killer blue, Speaker dampening wool was also placed inside.
The front panel was then cut from MDF and covered in Black lightning cloth to match the interior of the car. This was then sliconed in place, The sub was then bolted in place. A second piece of MDF was then cut, covered and screwed to the first panel. This panel would be the outer for the custom grill to hide the Sub.
The whole lot was then mounted in the boot (with much sweating and swearing as it was a VERY tight fit). Here you can see the box inplace with its custom cover in place.
The cover was made from a MDF frame attached to that was a grill made from 'Magic mesh' that was inbossed with the Rockford Logo. the whole grill as then covered in acoustic cloth.
Edited by Ruckus, 12 August 2008 - 09:21 PM.
