Uneven break pad wear
Posted 14 June 2005 - 11:20 AM
Drivers side: On of the pad looks almost new - 8mm of pad and the other is almost down to nothing!
Passenger side: Uneaven but no wear near as bad as the other side. Say 7mm to 4/5mm.
The calipers are fairly new - replaced approx. 2 years ago
What is the likely cause of this.
Pistons sticking?
Problem with the disc?
I think im going to book it in at a garage to get it sorted (I dont know enough about brakes to start messing with them safely) but wanted to know if it was a common problem. My next pads will be Green Stuff and I dont want them all messed up.
Cheers,
Charlie
Posted 14 June 2005 - 11:22 AM
Posted 14 June 2005 - 11:27 AM
Posted 14 June 2005 - 11:33 AM
Have you tried giving the brakes a bit of a bleed? Its a piece of cake to do.
Otherwise i'd have to say sticky or siezed pistons, but after only 2 years it seems unlikely.....
Posted 14 June 2005 - 02:24 PM
Posted 14 June 2005 - 06:49 PM
If Im going for Green Stuff pads I dont need to upgrade anything else do I? They are just direct replacements for the pads??
Posted 14 June 2005 - 06:55 PM
Posted 14 June 2005 - 07:26 PM
I bought greenstuffs as they were said to operate better at lower temperatures....are greenstuffs the ones that are designed to have their optimal performance at higher temperature than standard pads? if so then a) be aware that at normal temps they might not be as effective as standard pads and B) just make sure the fluids good quality as poor quality+old stuff has lower boiling point. Thats all I'd've thought, unless you want to go for vented discs air ducting and all that malarky!
Has to be said, the brakes to feel a lot better, but how much of that is just down to the fact they are new pads, I don't know...
Posted 14 June 2005 - 07:36 PM
Use a minimum of dot 4 brake fluid, but never mix, if you're going to use dot 5, you'd be better bleeding the entire system removing all the old fluid.
