Working Very Rough, Again! :-(
Posted 14 June 2008 - 02:25 PM
I have been using my 1970 mini 850 for quite some time now after a head gasket change (it's been about 4 months now), and it all went plain sailing. Today I started it and took it out of the garage so that I can give it a wash, and it started and sounded beautiful, as always. However, when I finished washing it up, I started it again and it sounded very awful!! Some first checks I did was, unplugged the HT leads one by one to see if there was any misfiring, and it turned out that when I removed plugs 3 & 4 (i.e the two fartest from the radiator), the engine behaviour remained unchanged, whilst when I removed plugs 1 & 2, the engine stalled. Therefore the problems seems to be coming from cylinders 3 and 4. I checked for spark and there is spark in all plugs and, since I don't have a compression tester, I cannot say whether there is the required compression, however when I removed the plugs in cylinders 3 & 4, it seemed that there was a bit of compression, or at least I could feel compression when I placed my finger in the plug hole. Also, checked the distributor, and enerything seems fine in there.
I also changed the rocker shaft because it had some play, and struck the valves with a soft hammer just to make sure that they aren't sticking..but the problems still persists.
Here's a video of the engine working at idle (it almost stalls at idle now, and there is loads of vibration!), so that you can get the idea of the strange noise it is making..any help would be greatly appriciated..
regards
Jeremy
Posted 14 June 2008 - 02:32 PM
sounds like head gasket.... unlucky. my 998 blows a head gasket between 3&4 every 2-3 months.
Edited by Broomer, 14 June 2008 - 02:33 PM.
Posted 14 June 2008 - 02:34 PM
Posted 14 June 2008 - 02:38 PM
only a compression test will reveal, but if youve got a spark and you remove leads 3 and 4 and it makes no difference, its likely to be head gasket.
Posted 14 June 2008 - 02:43 PM
I think I will be replacing the engine very soon then!!!
Can somebody else please confirm it's the head gasket???
Posted 14 June 2008 - 02:44 PM
Why would the gasket blow again after 4 months then??? I torqued everything up and did everything as it should be!
I think I will be replacing the engine very soon then!!!![]()
im not confirming it. did you have the head skimmed perviousaly? was the head retorqued after the initial fitting?
Posted 14 June 2008 - 02:46 PM
Posted 14 June 2008 - 02:47 PM
Posted 14 June 2008 - 03:09 PM
if you have just washed with a pressure washer a bit of wd40 to dry the electrics out may help
if its head gasket they usaully run rough at idle but smooth out a bit when you rev it (unless its really f@#?ed)
its unlikely for the head gasket to go just driving it out of your garage, unless you really thrashed it
Posted 14 June 2008 - 03:20 PM
I'm sure the leads are right, it worked perfectly this morning (and yesterday)!!
Posted 14 June 2008 - 03:24 PM
double check everything just to make sure its nothing serious.
i would do a compression test if everything else looks ok
any water in the oil or the cooling system pressurising up when its running, symptoms of head gasket faliure
Posted 14 June 2008 - 03:28 PM
Posted 14 June 2008 - 03:39 PM
Also, no water in the oil, however if the gasket has gone between cylinders 3 & 4, as far as I know it wouldn't effect the water and oil mixing up?
Posted 14 June 2008 - 03:43 PM
if it is the gasket between cylinders it should smooth out when you rev it up (unless its really fubar, unlikely to be that bad)
if it pops from the carb or stalls its probably ignition related
Posted 14 June 2008 - 03:47 PM
Well, it seems there's nothing else to do, I just have to replace it
