:turn: Thermostat
:turn: Fins on water pump for rotting away
:turn: Bubble in the radiator
:turn: Radiator blocked/nakkered
:turn: Water pump
Some of the first things you can try
secondly
If this still doesnt work then here are a couple of extra things to think of and check.
Headgasket may gone, check for what looks like "mayo" under the filler cap
Have you tryed a compresion test ? it could be the head gasket .
Is your fan working/running at the right speed? Also, is you temp sender/gauge working propperly?
Stupid Question, is the water level correct?
also is it losing water? you might have a leak
also, how high is the gauge going? to the top?...or just slightly over the 'normal' mark?
Whilst the gauge is above normal look under the bonnet, look for signs of hissing and or bubbling coming from the cylinder head, yep, ive done that one too! turned out to be a snapped head stud, meaning the head had lifted on one corner!
check your by pass hose about the water pump, ive had this go before.
if anyone else has any other ideas on things to check please post below.
or things that have happend to you.
