Roller rockers?
14 replies to this topic
#1 Purple Tom
Purple Tom
  • 4,921 posts
Posted 06 September 2004 - 05:51 PM
Hi,
I've always wondered about full roller rockers and roller tip rockers. Firstly, what is the difference between them? Secondly, what do they do? Am I right in thinking that they just increase the amount the valve opens?
I have a 266 cam fitted at the moment, so what are the implications of fitting full roller rockers or roller tip rockers? Is there any difference in noise or reliability between the two? Will fitting them make a difference in terms of power/torque, and are they worth the money?
Also, I notice there are several different ratios to choose from. Which is best for a lightly modified 1275 engine, with a 266 cam, stage 1 kit, HIF44 carb, slightly ported head but nothing major?
Sorry about all the questions, its just they've always puzzled me!!
Tom
#2 Pickup76
Pickup76
    Ring Runner 2005
  • 1,191 posts
Posted 06 September 2004 - 05:57 PM
Roller tip rockers are just to reduce the lateral load on the valves i think, and the different ratios are the amount more valve lift you get with them i think. Im not really an expert though, maybe the mini docs can correct me.
#3 philster
philster
  • 1,255 posts
Posted 06 September 2004 - 08:34 PM
roller rockers do not increase valve lift this is down to the ratio of the rocker. Roller rockers are mostly available in either 1.3 ratio or 1.5 .
1.3 i think is the standard ratio (someone correct me if i'm wrong)
This then leaves 1.5 which is a higher ratio so you get more valve lift.
Below is a simple (ish) diagram to show the difference (not exact only an example) between a standard and a high lift rocker.
On the second diagram you get more valve lift because of the change of pivot point which causes the rocker arm to move further with the same input from the push rod (which goes to the cam)
phew!
#4 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 07 September 2004 - 02:00 PM
They say a picture is worth a 1000 words... I think you have an essay's worth there.... great post philster...
and yes 1.3 is standard...
PS. What ever rocker you use they will not change the duration or timing of the lift, only the speed and amount... ie open and close faster and further with 1.5's (infact approx 15% faster and further )
#5 dklawson
dklawson
  • 10,923 posts
  • Name: Doug
Posted 07 September 2004 - 04:46 PM
Excellent picture post!
1.3:1 may be standard on later engines but for early 1275s like mine the Cooper-S forged rockers were 1.22:1 (nominal).
I have stock rockers for the moment but someday will install high-lift rockers. A friend of mine with a Spitfire installed the equivalent of 1.5:1 rockers on his 1300 engine. He did some un-scientific time/distance sprints on a local road before and after the installation. He claims to have shaved a couple of seconds off of his 1/4 mile times. Again, it was un-scientific but did show an easily measurable improvement on an engine comparable in size to that of the Mini.
#6 Woody
Woody
    Ring Runner 2005
  • 1,763 posts
Posted 07 September 2004 - 05:43 PM
I have fitted 1.5 ratio roller rockers on my 1275cc engine and the differance is definatly noticable out on the road , the acceleration is better and i have a few mph more on top end .
#7 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 07 September 2004 - 06:01 PM
The Cooper S forged rocker was the first one to be built to 1.3. All the others (the pressed steel ones, standard forged ones and even the very late nasty sintered ones) were 1.22ish as you say. I run Cooper S forged rockers in my 998 and they are great. They have a nicely profiled nose which does a lot to reduce side loading, but not as much as the roller sets obviously. Roller sets reduce internal friction losses greatly which is why you will see a performance increase even with a near standard ratio. They are also very light in weight and so reduce the inertia of the valve train meaning the engine can theoretically accelerate faster, although this is usually hindered by other components.
#8 philster
philster
  • 1,255 posts
Posted 07 September 2004 - 07:42 PM
Although i know how roller rockers work i have never actually fitted any, does anyone know if there are any downsides to fitting them or is it all good! Also i'm assuming they could be fitted to a standard 1275 setup without problems.
I'm now a firm fan of bolt on power after spending a fortune on my old 998 lump for around 60horses and ending up with a very unreliable engine.
I was also thinking of purchasing a spare head for the mg lump and having it ported, putting better guides in and converting to unleaded. Would a machine shop do this obvoiusly i won't need bigger valves because the mg head is about as big as you'd want to go on a road car anyway so would it be cheaper than buying say a stage 3 head off the shelf?
#9 Bluemini
Bluemini
    Mini Doctor
  • 4,436 posts
  • Local Club: Blacktop Bombers
Posted 07 September 2004 - 10:36 PM
One thing you need to watch out for when fitting larger ratio rockers is the amount of coils the valve springs. I had a set of 1.5's on one head and they were fine, I put them on another head and the valve spring was pressed down that far on full lift that all the coils touched, ending in bent valves!! There are a couple of ways round this, either buy uprated springs with less coils or get the spring seats machined out a bit.
#10 minimadjonesy
minimadjonesy
  • 6,417 posts
  • Local Club: SMAC
Posted 08 September 2004 - 06:42 PM
also, a minor thing that I have foundon the various cars in the club with these fitted is that they do tend to knock the rocker cover! One of the lads had them fitted by vmaxscart and even they said that this was a problem!
#11 TimS
TimS
    Mini Doctor
  • 2,712 posts
Posted 08 September 2004 - 06:53 PM
the difference i found is the at power band moved further up the rev range
#12 Bluemini
Bluemini
    Mini Doctor
  • 4,436 posts
Posted 08 September 2004 - 07:38 PM
The rocker cover needs modding, if you fit the flat top alloy type, you need to grind out an area at the back of it on the inside to give the adjuster screw area some clearance. I have managed to get a metro sloping type one to fit on mine without having to grind it.
#13 Woody
Woody
    Ring Runner 2005
  • 1,763 posts
Posted 08 September 2004 - 09:40 PM
had to take the metro lid off mine as it sounded like a machine gun :P
plenty of room under the steel lid .
#14 kvrt
kvrt
  • 14 posts
Posted 15 June 2013 - 03:25 PM
I know this subject is a bit long in the tooth now but maybe anyone thinking about fitting roller rockers may be interested in my experiences. I have a 998 Mk2 Cooper which is currently undergoing a ground up rebuild having been seriously abused during the 70s and 80s. Whilst rebuilding the engine I decided to fit roller rockers to reduce the wear on the valve guides. Having acquired a set I began the task of fitting them to the head. On advice of Sean Brown from Flowspeed in America I carried out all the measurements and the shimming to align the roller ends to the valves. So far so good. However, when I lowered the head on to the block and fitted an adjustable push rod in order to ascertain the required length I found that the push rods were not running vertically. I have been unable to find a set of rockers in which the roller end is not offset as the standard arm ball end is in direct line with the centre line of the valve. Does anyone know a manufacturer who makes roller rockers which will fit 12G295 Cooper head? I only want 1:1.3 ratio. Hope someone can help!
#15 Ethel
  • 25,897 posts
Posted 15 June 2013 - 04:48 PM
https://www.somerfor...oducts_id=15000
Minispares do 'em too, but are out of stock, might be worth ringing first.
