By AC Dodd
http://p211.ezboard....opicID=51.topic
Aftermarket Cams
First off is the excellent Swiftune SW5 road cam, these figures are based on my observations based on 2 new examples I measured about 2 years ago. The figures are to be read as average of the 2,
Checking height: 0.016" @ lobe
Timing: (Intake): 16/48 (Exhaust): 52/12
Nominal lobe lift: (Intake): 0.281" (Exhaust): 0.281"
Duration (Intake): 244 (Exhaust): 244
Lobe centre angle (Intake): 106 (Exhaust): 110
Lobe separation angle: 108
Lift on overlap: 0.036"
Accuracy: Good
The next in the Swiftune family is the SW10, which is basically a real hot road cam like a 286 but with better emissions and suited to road use where wear characteristics are more important than outright performance.
b]Checking height:[/b] 0.016" @ lobe
Timing: (Intake): 34/66 (Exhaust): 70/30
Nominal lobe lift: (Intake): 0.291" (Exhaust): 0.291"
Duration (Intake): 280 (Exhaust): 280
Lift on overlap: 0.070"
Accuracy: Good
Next is the much under used Kent 246 a nice all round road cam that has a little more bite than the SW5, these figures are based on kents own specs, plus with my own additions looking at 1 cam.
Timing: (Intake): 18/54 (Exhaust): 54/18
Nominal lobe lift: (Intake): 0.285" (Exhaust): 0.285"
Duration (Intake): 252 (Exhaust): 252
Lobe centre angle (Intake): 108 (Exhaust): 108
Lift on overlap: 0.048"
Accuracy: Good
Next is the Kent 266 a nice all round road cam, these figures are based on kents own specs, plus with my own additions.
Timing: (Intake): 24/56 (Exhaust): 61/29
Nominal lobe lift: (Intake): 0.263" (Exhaust): 0.268"
Duration (Intake): 260 (Exhaust): 270
Lobe centre angle (Intake): 106 (Exhaust): 106
Lobe separation angle: 106
Lift on overlap: 0.054"
Accuracy: Average
Here is the Kent 276;
Timing: (Intake): 29/61 (Exhaust): 66/34
Nominal lobe lift: (Intake): 0.293" (Exhaust): 0.315"
Duration (Intake): 270 (Exhaust): 280
Lift on overlap: 0.078"
Accuracy: Below Average
Here is the 286;
Timing: (Intake): 34/66 (Exhaust): 71/39
Nominal lobe lift: (Intake): 0.315" (Exhaust): 0.324"
Duration (Intake): 280 (Exhaust): 290
Lift on overlap: 0.088"
The Kent 296;
Timing: (Intake): 39/71 (Exhaust): 76/44
Nominal lobe lift: (Intake): 0.324" (Exhaust): 0.340"
Duration (Intake): 290 (Exhaust): 300
Lift on overlap: 0.112"
Accuracy: Average
Kents Version of the good old 649;
Timing: (Intake): 43/64 (Exhaust): 61/40
Nominal lobe lift: (Intake): 0.323" (Exhaust): 0.323"
Duration (Intake): 287 (Exhaust): 281
Lobe centre angle (Intake): 100.5 (Exhaust): 100.5
Lobe separation angle: 100.5
Lift on overlap: 0.110"
Accuracy: Average
Piper's BP300. These figures are based soley on the average of 3 cylinders checked in my jig.
Timing: (Intake): 47/75 (Exhaust): 75/47
Nominal lobe lift: (Intake): 0.315" (Exhaust): 0.315"
Duration (Intake): 302 (Exhaust): 302
Lobe centre angle (Intake): 104 (Exhaust): 104
Lobe separation angle: 104
Lift on overlap: 0.125"
Accuracy: Good
The Morspeed phase 2 (Fast road) Based on 1 example only;
Timing: (Intake): 20/52 (Exhaust): 56/16
Nominal lobe lift: (Intake): 0.305" (Exhaust): 0.298"
Accuracy: Good
The Morspeed phase 3 (trackday cam) Based on 1 example only;
Timing: (Intake): 27/63 (Exhaust): 63/27
Nominal lobe lift: (Intake): 0.315" (Exhaust): 0.311"
Duration (Intake): 270 (Exhaust): 270
Lift on overlap: 0.065"
Accuracy: Good
Keith Calvers (not his own I know) , RE13 Based on 1 example only;
Timing: (Intake): 34.5/61.5 (Exhaust): 63.5/32.5
Nominal lobe lift: (Intake): 0.290" (Exhaust): 0.290"
Duration (Intake): 276 (Exhaust): 276
Lobe centre angle (Intake): 103.5 (Exhaust): 105.5
Lobe separation angle: 104.5
Lift on overlap: 0.085"
Accuracy: Good
Ok, a little differnt this time, but a very good cam company none the less, this is a B646 from NEWMAN cams Based on 1 example only;
Timing: (Intake): 14/58 (Exhaust): 51/21
Nominal lobe lift: (Intake): 0.302" (Exhaust): 0.298"
Lobe centre angle (Intake): 112 (Exhaust): 105
Lobe separation angle: 108.5
Lift on overlap: 0.047"
Accuracy: Good
List of Cams and Timing figures etc
Jordie
, Dec 03 2006 03:05 PM
2 replies to this topic
Posted 03 December 2006 - 03:05 PM
Posted 03 January 2007 - 07:59 PM
The Kent 246 is also a high torque cam designed for the ORC Ministox that I race so i think it would be a good hillclimb cam being a high torque camshaft
My power + torque figures illustrate how torquey this cam is (bare in mind i have to run a restrictor plate between the carb and manifold that has an 18mm hole in it)
36.1 bhp and 50.4 lb/s of torque
It also gives good power as my car is the most powerful at the track i race at (not boasting or anything)
Posted 28 January 2009 - 01:41 AM
Thought i'd add this great cam info list - So it doesn't get lost again
http://www.edhodson....o/Mini Cams.xls
