SPi running problems, any input welcome...
Posted 03 April 2006 - 09:00 PM
Its rich, all the time, have had it plugged up to a the snap on reader, its bring up map sensor. You think easy, change the ECU and all will be fine. Changed it for an ECU that is perfect, still won't run properly. Earlier problem included a blocked injector, engine is brand new, basically done 15 miles at best. Injector is now changed for a working one, it now idles noirmally, but when you try to put it under any load when you drive it, it missfires. Compression is 190 across the board, but it will just not take full or even half throttle when you try to drive it. Any clues? theres no air leaks, map sensor pipe is unblocked, fuel pump runs ok, everything on the engine is new, dizzy cap, leads, plugs, everything! Plugs are gapped, take them out they are black. Lamdba relay is working ok, no other faults are being brought up by the readout machine. Anyone had this before?
Does it need resistor plugs as it has BP6ES's in it at the moment, (new), do I need BP6ES 'R's??
help!
Rich.
Posted 03 April 2006 - 09:19 PM
Posted 03 April 2006 - 09:25 PM
Definitely sounds something fishy with a sensor. Could be a dodgy temperature sensor, or lambda sensor. These I believe may actually fail without bringing up a fault in diagnostics. Seems you've changed all the consumables and ruled out head gasket problems, so sensors seem the next step!
the lambda relay on the bulkhead is switching in an out, but I don't know if the sensor has failed. Although it idles, it idles quite low, 600 rpm, even on the very mild 274 Kent cam, its makeing the idler gear rattle a little.
The car was laid up over 5 years, first time it was started up it was all ok, and has just got progressively worse.
Its on an LCB, we plugged my supposedly "knackered" ECU into a perfectly healthy SPI, and it was fine, ran sweet as a nut. Coolant temp sensor is plugged in ok with clean connections I guess all it can be is the lambda. I'm sure the plugs would not make it run like this. but its very rich, fuelling is causing it to missfire all the way dwon the road, its virtually undriveable.
Rich
Posted 03 April 2006 - 10:19 PM
It sounds that way too. permanently rich meaning if the map sensor is down, it'll be assuming the air flowing into the throttle is totally wrong, and will compensate by richening it up.
Posted 03 April 2006 - 11:05 PM
Is the ECU the correct one for the compression ratio you are running. 10:1 = ECU from cooper, 9.4 = ECU from spite or Mayfair.
Throttle position sensor can cause major problems with rich running. Temp sensors need to be checked against a calibrated thermometer. Use the Snapon to give you the information, it is than up to you to prove it one way or the other. Lambda sensor volts need to swing high low at least once a second between 0.2 volts to 0.6volts for it to be working correctly. Leaking exhaust manifold can cause rich running
My bet is its out of tune, and either coolant sensor or throttle sensor. Fit the right plugs NGK BPR6ES
call me silly, but if the diag says its a faulty map sensor, then have you tried changing the map sensor?
OOh now that makes me think
Deffo sound like a MAP sensor issue
if the ECU works fine on another car, then the only thing it CAN be is there is a blockage in the capilary tubes and id suspect that one of the elbows has been pushed on way to far blocking its oriface.
Failing that, replace the lot from the manifold to the ECU including the fuel trap
It will still need tuning though, thats for sure
Posted 04 April 2006 - 01:22 PM
Posted 04 April 2006 - 06:09 PM
this sounds a similar problem I have now with my mpi !!
When was the Lambda sensor changed???
Posted 04 April 2006 - 06:17 PM
no idea ?!?!
Posted 04 April 2006 - 10:04 PM
The pipe work to both is clear, blow through the fuel trap and suck back through it and taste (yum) fumes. from the back of the manifold to the ECU is clear and not leaking.
I can fit the right plugs, but how do you "tune " it?
How do you adjust the throttle position sensor/Coolant temp sensor?
which is the colour wire on the lambda to make to take the readout off?
Rich
Posted 04 April 2006 - 10:21 PM
Posted 04 April 2006 - 10:35 PM
switching the ingnition to "on". Press my foot flat on the throttle and then off.
Reset the ECU.
Press the thottle pedal up and down 10 times with the Ignition on
Rich
Posted 04 April 2006 - 10:49 PM
why can't mems be like motronic? most motronic codes can be read by usinga paperclip in a certain plug, read off a flash code, it will tell you exactly which sensor it is, wether its high or low voltage (low usually indicatinga broken wire, high indicating a knackered sensor)
quality rover strikes again.
Rich
Posted 04 April 2006 - 11:13 PM
here goes, I VERY much doubt its the coolant temp sensor, as the temp gauge works accurately comes up off zero and will happily sit @ half or tiny bit below when warm. HAS to be:
lambda sensor/air intake temp sensor, OR map sensor. although even though the snap on machine bought up map sensor, why would plugging another ECU into it, cause it to give the same problems?
after reading the FAQ SPi page this is all I can think off, anyone else care for input?
Rich
Posted 05 April 2006 - 09:44 PM
Posted 05 April 2006 - 10:21 PM
It doesn't matter now anyway, I've got someone to fix it hopefully, as I'm fed up with the rovers mems absolute and utter *******. Minis should have just been left on carburettors, with distributors, they are no where near advanced enough to need EFI at all.
Rich
