Blue Hylomar - Where To Use And Where Not To Use?
15 replies to this topic
#1 charliedurrant
charliedurrant
  • 519 posts
  • Local Club: There isn't one down my way
Posted 25 October 2011 - 11:13 PM
The title says it all. I'm soon to do a rebuild and it would be good to know where and where not to use the stuff...
Charlie
Hylomar
1) Heater control gasket
No Hylomar
1) Head gasket
#2 Cooperman
  • 23,278 posts
Posted 25 October 2011 - 11:16 PM
Never use any sealant on the head gasket.
#3 Daviewonder
Daviewonder
    Needs an extra inch!!
  • 1,019 posts
Posted 25 October 2011 - 11:23 PM
I've always used Welseal on headgaskets.
#4 dklawson
dklawson
  • 10,923 posts
  • Name: Doug
Posted 25 October 2011 - 11:49 PM
In the days before I had a Mini I routinely used sealer on head gaskets. A company over here sells a product called K-W Coppercoat. It is a thin sealant spray containing powdered copper. You were supposed to just put a flash coating on the gasket to help it seal to the block and head.
On the Mini and my other British cars I've always put head gaskets on dry. This is particularly true for the black Payen gaskets which have a sealer already on their surface.
#5 MRA
MRA
  • 7,607 posts
Posted 26 October 2011 - 12:51 AM
The black Payen gasket is part number BK450 and is an excellent head gasket with good sealing characteristics.
#6 charliedurrant
charliedurrant
  • 519 posts
Posted 26 October 2011 - 04:23 PM
Okay, MRA - I've pinched some pics off your site (excellent value gasket sets by the way). If you object I can delete from my post. My challenge is to:
1) Name that gasket
2) Say if hylomar can be used
So
Gasket 12, Hiff 34/44 carb elbow gasket, Hylomar = Yes, especially when using a K&N cone filter as the plate never seems to sit flat!
Gasket 13, Heater valve union, Hylomar = Yes
Gasket 14, Themostat housing to cylinder head / later type pancake fitting for bypassless heads, Hylomar = Yes
Gasket 15, Exhaust, Hylomar = No (it can be but it makes a right mess when you fit it)
etc
Are there anymore gaskets?
Charlie
#7 MRA
MRA
  • 7,607 posts
Posted 26 October 2011 - 04:59 PM
Blue Hylomar is not any good if petrol is in the same area....
(The specifications for Blue Hylomar have been added below and apparently it can be used for sealing gaskets where petrol is involved)
You can always add the links to our gasket sets as well :) .....
Edited by mra-minis.co.uk, 29 October 2011 - 10:33 AM.
#8 charliedurrant
charliedurrant
  • 519 posts
Posted 26 October 2011 - 05:26 PM
Martin,
According to the pdf sheet at
http://www.hylomar.c...3&Itemid=75
It's fine with petrol and specifically says it can be used on fuel inlets....My udersntading is that it can not stay submerged in fuel....
Charlie
source gasket image links
http://www.mra-minis...-gasket-set.htm
http://www.mra-minis...set-C-EF462.htm
Edited by charliedurrant, 26 October 2011 - 05:28 PM.
#9 charliedurrant
charliedurrant
  • 519 posts
Posted 26 October 2011 - 05:30 PM
Well I'll add another
Gasket 11 - Hiff 44 carb -> carb spacer -> abutment plate -> inlet manifold, Hylomar = Yes (but I wouldn't bother)
#10 mini93
mini93
    He's just too casual!
  • 8,615 posts
Posted 26 October 2011 - 05:32 PM
Southam built my engine with a smear of some kinda wurth sealent at the very front of the headgasket, they say as a preventative thing about the water ways... cant question it, probably know more than most on here :lol:
#11 MRA
MRA
  • 7,607 posts
Posted 26 October 2011 - 05:54 PM
Martin,
Charlie
I sit corrected..... it didn't work almost 30 years ago on my rally Mini though :D I had to find someoen who had the yellow version :)
#12 charliedurrant
charliedurrant
  • 519 posts
Posted 26 October 2011 - 06:55 PM
Can anyone name the other gaskets?
#13 liirge
liirge
  • 4,097 posts
  • Local Club: EDMC AND MMC
Posted 26 October 2011 - 07:26 PM
Timing gear case!!
at the bottom of it where oil pools, always worth a dollop, as it always seems to leak.
Also a manual I have recommends a generous smear around the half moon seal.
Edited by liirge, 26 October 2011 - 07:26 PM.
#14 charliedurrant
charliedurrant
  • 519 posts
Posted 26 October 2011 - 07:52 PM
Is the timing case number 9 and the half moon the rubber half moon one I have not numbered? I assumed a rubber seal would not need hylomar...
#15 charliedurrant
charliedurrant
  • 519 posts
Posted 28 October 2011 - 10:49 PM
Anyone man enough to name a gasket and tell me if Hylomar is sensible. I am being entirely selfish as I have an engine to rebuild and it would be great to know......
