Hi guys,
Following a fair bit of interest I am now selling complete bucket seat mounting kits. To be honest you could fit 99% of seats with these, not just buckets, but they do need welding in.
I am working on bolt in versions but they would not be suitable for motorsport use.
Anyway here's a couple of pics:
SEAT RAILS 1.jpg 32.5K
76 downloads
SEAT RAILS 2.jpg 44.31K
63 downloads
IMG_0109-1.jpg 49K
194 downloads
The kit for 1 seat includes:
4x spreader plates, 80x60mm, 3mm thick
2x round tubes, 600mm long, 25.4mm diameter, 3mm wall
4x mounting brackets, laser cut from 3mm mild steel, a good 40mm lateral movement, purpose made deep M8 square nuts floating in welded channel
The items will need trimming and flat plates forming to fit, I can fold the ones for the sills to save you some work if required, the ones which weld to the tunnel will need to be bent to shape which can be done in a good vice.
Price is £35 plus postage for 1 set (for 1 seat), or £65 plus postage for 2 sets, courier is £8 set cost for UK addresses.
I can make these (and almost anything) to whatever spec is required, I now only use 10g CDS tubing, although this is about 3 times more expensive than cheaper ERW tube, it is generally required by the MSA and to my knowledge my kits are the only ones available which actually comply with the MSA Blue Book specs, which state that all fixtures etc must me a minimum of 3mm thick!
Any questions welcome!
Thanks,
TC
Edited by TopCatCustom, 29 October 2013 - 03:29 PM.
