The head came off, re cut valve seats & built it back up with head skim (To Re-dress the valve seats. De-coke the head + re-cut the seats + a 2thou skim cost me ยฃ65).
It had a Copper AF460 gasket fitted http://www.minisport...info_AF460.html and has done the following events since then:
Track day
Autosolo
4x Rally Sprints
2x Woodbridge rally sprint
[diligently cleaned cooling system/Rad using a hose and Holts Rad Flush (2-step) http://www.halfords....tegoryId_165750 The water was running clear by the time I had finished, but I did spot a few flakes of rust lodged in the matrix of the car's brass 4-Core Rad subsequently, which was irritating. I refilled it with fresh Comma Red OAT antifreeze -which I confirmed was definitely OK for classic Minis -and distilled water).
A few hours of road driving (mainly on 1 day a couple of weeks before the Track Day)
Track day
The temp has been normal on all events, but they are often 'short bursts' i.e. 3-8 minute stages, typically. At Woodbridge we noticed that the Temp would be 25% above 'N' at the end of each stage but we drove around for a few minutes to get some airflow through the Radiator (Rad) before returning to the paddock each time and no problems resulted.
However, on the final event in the list above I noticed in the morning that the temp gauge (which has a scale of ' C N H') was halfway between N and H (and there was a light spray of coolant droplets on the passenger side of the windscreen) so I came off the track.
We continued to closely monitor the coolant level during the day and on each track session it would get hotter than 'N' and then spray a bit of coolant onto the windscreen after 5-7 laps. Looking at the water marks on the rad, I think it might have been bubbling out of the radiator cap and dripping onto the fan, which fits with the spray pattern I saw inside the engine bay. However, I don't know why the coolant wasn't going out down the overflow pipe in the radiator filler neck (I checked the pipe wasn't blocked).
The engine also sounded a bit rough and this got worse throughout the day. There is evidence of a small coolant leak out of the cyl head gasket on the front of the engine block (white/pinky staining from my Red AntiFreeze which got more obvious during the day).
We have done a Compression test and it was about 150psi in all 4 cylinders which I understand is well down? Back in 09, the cyl hd gasket failure was detected by cylinders 2&3 producing about the same psi (and the good cylinders were about 175psi).
- Anyone got any ideas as to why the Cyl Hd Gasket isn't lasting that long?
- The Minisport link to the gasket quotes it as for '1275/1400 engines' -my block is 1293cc so would this be causing a problem?
- Are the Head Studs 'stretch bolts' i.e. should I have replaced them when the Hd was off last time?
- I have just checked the Head bolt torque and they were all spot on 40lb/ft (as specified in the manual) apart from the one that is on the front right of the engine from the Driver's perspective (this needed approx 1 extra turn to make 40lb/ft). My mate was saying that I need to re-check the head bolt Tq every couple of outings on a rally engine (although this is a pain when it means having to glue a new Rocker Cover gasket on each time)
- Perhaps my problem is that the BLOCK is warped (rather than the head)? [I hope not because that is presumably an 'engine out' job to skim the block?
- Is there any head gasket cement that will help (especially if the car does have a warped block)? e.g. http://www.audioworl...hp?topic=2936.0
- Do I need to get Competition Head Studs? The ARP ones are hugely expensive! http://www.minisport..._and_Studs.html
- My intention is to try fitting the BK450 Metro Turbo Gasket (and buy the whole BK450 Gasket set) http://www.minisport...40BK#aGEG1140BK
If it fails again, then the only other option I have is this one:
HEAD GASKET COMPETITION 1300 AND 8 PORT
http://www.minispare...=...5695&title=
However, the other question is:
"Did the engine get too hot and then blow the gasket" OR "Did the gasket blow and cause the coolant to get hot"
Could the water pump have been turning so fast at the high revs involved (4000-6000rpm continuously) that the coolant was cavitating (and so the pump would need to be slowed down via a larger pulley wheel)
I intend to buy and fit this Oil Cooler:
http://cgi.ebay.co.u...=item20b78f10ce
and I could always try getting better cooling on the engine e.g.
Remove Rad and soak it in Bilt Hamber DEOX-C overnight to dissolve any rust inside: http://www.bilthambe.....osion Removal
If the car's still getting too hot, I could try Redline Water Wetter http://www.redlineoi...ts.aspx?pcid=10
or a new Aluminium Rad (or even a front-mounted Metro Rad but this sounds like a lot of work to make it fit).
The possibilities are endless! Any advice on how to sort out this problem would be much appreciated...
FYI, the carโs full spec is listed on the its blog:
http://www.theminifo...howtopic=129848
Edited by John Clayton, 24 May 2011 - 06:26 PM.
