Bonnet Scoop = Cold Dense Air To Intake =more Bhp?
Posted 23 April 2011 - 08:14 PM
I accept that the Ram Air effect is likely to give a negligible power increase (although I gather that sports bikes gain some benefit at very high speeds), but a bonnet scoop to pull Cold air in and straight onto the Air Filter (rather than hot less dense air from under the bonnet) has got to make a difference, hasn't it?
http://en.wikipedia....wiki/Hood_scoop
"The high operating temperatures in the engine compartment result in intake air that is 28°C (50°F) or more warmer than the ambient temperature, and consequently less dense. A hood scoop can provide the engine with cooler, denser outside air, increasing power."
On rolling roads the engine's usually tested with the bonnet up/removed, and so plenty of cold air's available -not necessarily the case when the car's being driven with the bonnet down.
Details on my rally car's spec are here, FYI:
http://www.theminifo...x...=129848&hl=
Posted 23 April 2011 - 08:26 PM
Posted 23 April 2011 - 08:28 PM
Posted 23 April 2011 - 08:33 PM
Posted 23 April 2011 - 10:00 PM
Posted 24 April 2011 - 01:21 AM
Posted 24 April 2011 - 11:11 AM
Dan has just explained it is not needed, as the engine bay is vented very well, another reason why heat wrapping is not neededbest way i recon is the era turbo bonnet scoop . letting hot air vent at the back . thats what i will be doing along with wraping my lcb
Posted 25 April 2011 - 10:09 AM
The bonnet scoop on an ERA or MG Metro turbo was there to cool the carburettor only...... just look at the position of the air intake on both
The cool air over the carburettor helps to stop the fuel from evaporating due to the heat of the turbo, evaporation of the petrol causes starting issues....
Edited by mra-minis.co.uk, 25 April 2011 - 10:11 AM.
Posted 25 April 2011 - 10:50 AM
Posted 25 April 2011 - 10:58 AM
Why does my MiniSport inlet manifold have the coolant running through the centre of it? I assumed the heat was there to either stop the carb icing up or to help the fuel to vapourise
Posted 25 April 2011 - 11:03 AM
Posted 25 April 2011 - 11:12 AM
Posted 25 April 2011 - 11:16 AM
Posted 25 April 2011 - 12:40 PM
Did the car have inner wings when it had a GRP front?
No, nor support bars on the subframe. Oh blastphemy .
