Extra modifications to think aboutGearboxThe gearbox on the A series engine is often thought of as the weak cog. Its fine in standard trim sat under a standard (or near standard) engine, but once you starting pumping more power and (more importantly) more torque through those gears it all starts to become a little shakey!
The first thing you want to look at is making sure your standard gearbox is in good working order. That means that the gearbox doesn't crunch as you try to change gear (a sign the synchromeshes could be on there way out) and that there isn't too much 'slop' in the gear changes, or when the gear lever is sat in a gear. Start putting more torque through an old, tired gearbox and you'll rapidly wear it to a early death!
Once you know your gearbox is in good order you can start to think of modifications, which generally start with a competition Molybdenum differential pin. This is a harder wearing differential pin, for putting that power to the ground around those corners. To fit one though it does entail having the gearbox off the engine (however so do any gearbox mods!). It's a cheap modification too, at ~£25 for the pin, and then cost of labour for fitting if you don't wish to fit it yourself.
The next step up for the differential is to fit a cross pin differential, which adds two more planet gears, helping to transfer the power to the wheels, and reduce wear due to having doubled the number of gears and pins that are taking the power/torque. At between £150-£180 a X-pin diff is much more expensive than the competition diff pin, but they are generally considered almost bomb proof.
Minispares Molybdenum Cross pin diff
The ultimate for differentials is to fit an LSD (Limite Slip Differential), but be careful, there are several different types designed for different situations, with certain types that you really don't want to use on the road! A couple of examples that you could use on the road are the 'Evolution' LSD available from Minispares, and the Quaife ATB available from Quaife. Whilst they do give very good handling in most situations, costing £470 and £500 respectively, means that most people do not deem it necessary to fit an LSD. Also be aware that fitting an LSD means that you will probably have to either modify your crownwheel, or buy a new crownwheel, adding yet more to the cost.
One upgrade that is often asked about on TMF is straight cut gears, both gearsets and drop gears. Rather than having the teeth cut at an angle (something that reduces the noise from the gears) the teeth are cut perpendicular to the rotation of the gear. This reduces the 'side loadings' on the gear and thus the friction, meaning you can reduce the loses you get through the transmission by 2-5bhp typically. Straight cut drops do nothing more than give you more noise and reduce the side loadings, and expect to pay between £150 and £200 for a set. Straight cut gearsets can often be bought as 'close ratio' sets, meaning for 1st, 2nd and to an extent 3rd you get more mph per rpm. Note that 4th gear stays the same (1:1), meaning that your top speed will not change. Striaght cut gearsets are usually priced at between £350 to £600 depending on who you buy a set from. If you wish to find out what straight cut gears will sound like in your car, find a big open space and drive about with the car in reverse. All reverse gears are straight cut, therefore the noise you get from your reverse gear will be the same as all the gears on a straight cut gearset/straight cut drops.
There is also the option for 'dog' gearboxes and there is even a sequential gearbox on the market, but I believe they are out of the relms of this FAQ.
Extra Reading:
Minispares Article: Up-Rating Drop gears,
Minispares article: Synchro vs Dog engagement.
Places to buy:
Guessworks.com - for all your gearbox needsClutch and flywheelWhilst neither the clutch or flywheel will help to release power, they can certainly help with the performance of the engine, and the clutch (pre-Verto especially) is designed to take specific power/torque outputs. First off you need to work out which clutch you have pre-Verto or Verto (
FAQ here). Most people, if they have a Verto clutch, decide to change it to pre-Verto if they plan to modify their engine a lot, largely due to the number of choices that are available for the pre-Verto set up/aren't available for the Verto set up.
I believe for the Verto set up you are limited to an uprated flywheel (lighter, therefore quicker acceleration), a turbo clutch plate, and a turbo cover (which provides more clamping pressure to handle high power outputs - but for non-injection engines only). Compare that to the choices for the pre-Verto set up; you can have a modified standard flywheel, or very lightweight Steel flywheels, four (technically six) different diaphragms, lightened backplates and the option to use a paddle clutch plate. With the pre-Verto diaphragms; standard (blue), Orange, Grey and Double Grey, are made to cope with different power outputs before they start to slip. Blue is standard, and could be used on an engine producing upto about 60 Lbft of torque, Orange goes up to 74 Lbft, Grey I have yet to confirm, and Double Grey is a massive 1250 Lbft!
The idea behind getting the clutch and flywheel assembly as light as possible is to reduce the rotating mass, which means the engine has to put in less effort to rotate, and can 'spin up' quicker, leading to quicker acceleration. However, this can have a downside in that it can sometimes cause quite a lumpy idle (ie. the engine doesn't want to sit at a certain rpm, but jumps up and down). However this doesn't just depend on the flywheel/clutch assy, but also on the engine size, camshaft, rocker ratio, so its best to check with an expert who can advise you on whether a lightweight assembly would be suitable for your engine, and your needs.
Steel Utralite flywheel available from Minispares
CoolingTo be honest the standard cooling system, when in good condition, can handle a lot of modifications and extra heat chucked out from the engine. Make sure you use distilled water (to stop parts within the cooling system rusting), and the proper quantity of antifreeze. Upgrades can include 2 or 4 core radiators, 'Water Wetter' (an additive that can be used to make the water absorb more heat), and Silicon hoses. With regards to the radiator, the 2 core 'Super' radiator Minispares produce is regarded as one of the best for cooling. Not only is it one of the lightest, but it also performs just as well as the larger 4 core radiator. However, the fins can be prone to damage, so for harsh environments, like grasstracking, its better to go with the 4 core. The standard fan is also up to the job of cooling almost any A-series engine. Not only is it quite light, and quiet, its also has aerofoil blades which make a very good job of directing the airflow through the radiator. Bare in mind that above 30-35 mph the fan is redundant. Silicon hoses look pretty! Not only that but they are also able to withstand higher temperatures and greater pressure than there standard rubber counterparts, and another advantage is that they won't perish like rubber hoses. Making them a great upgrade if you like pretty things that also have a worthwhile purpose!
MiniSpares 2 core 'Super' radiator
With regards to how much this will all cost, well expect the 2 or 4 core 'Super' radiators to set you back between £65 and £80 depending on the model of car/engine you have. A silicon hose set will set you back a further ~£70.
