What Size P-clips?
Posted 09 April 2011 - 12:22 AM
Does anyone know what size clips I need for each of these?
Posted 09 April 2011 - 08:14 AM
Posted 09 April 2011 - 12:14 PM
Excellent! I'll get some ordered.You can use 8mm for brake and fuel lines then 10mm for the battery cable.
Cheers!
Posted 12 April 2011 - 07:48 PM
Hoping to do this myself, but can't decide what to do.
Posted 12 April 2011 - 07:54 PM
Posted 12 April 2011 - 08:01 PM
How are you planning on attaching the p-clips? Have you gone for some elaborate bolt through type affair, or just screwing them in with self tappers?
Personally i drilled some 3/16th holes inserted some screws and welded them in place.
Posted 12 April 2011 - 08:12 PM
I thought that too Tom, I actually ordered 5mm ones for the brake lines and 8mm for fuel lines.8mm on brake lines??. It says on my bag of brand new brake line - outside diameter 4.72mm.
Sonikk, why do you do this to me man?! That looks much better than my rivet in place scenario is going to .
Might stick to my guns on this one though just because riveting will be quicker and easier. Plus as mine are going to be on the under side still, those threads will get exposed to the elements, which wouldn't be good.
Posted 12 April 2011 - 08:18 PM
The thing with rivets though you may be opening a can of worms as unless you use steel rivets then you will get dissimilar metal corrosion.
You can chop the threaded bit down and then a touch of sealant on the exposed end will make it all nice and water tight.
Posted 13 April 2011 - 07:38 AM
Posted 13 April 2011 - 07:50 AM
