It has been sitting there since October and finally started the stripping it out and using Albert as the donor for Albert II.
The car has been SORN and sitting around since 1996, so as expected some (alot) rust patches. So here is my attempt at restoring the car. The final goal is to have a car with the following spec:
1380 Fast Road engine with lightened flywheel, KAD 286, duplex timing chain,uprated radiator and electronic ignition. The metro engine from Albert will be used for the rebuild, as the current engine is seized up.
4 pot caliper breaks, hi-lo suspension.
Poly bush mountings all around.
As for body work, there is a fair bit to get on with. Both sides outer seals and the entire front end needs replacing, including the inner wings and scuttle panel. I have taken some pictures, which I will upload later. Luckily the rest of the car is in a good condition, I have no idea how the rest has stayed rust free as it was sitting in a yard, it even had some weeds groing in the engine bay (lost the pictures for that since the camera decided to have strock and delete all pictures).
As I have become abit of an expert on painting with Rustolem, I will be painting it with an Earlex 3000 HVLP gun that I bought last year for Albert.
Edited by Hekmat, 28 June 2010 - 07:20 AM.
