too servo or not too servo.........
20 replies to this topic
#1 markrally
markrally
    Z Cars
  • 1,378 posts
  • Local Club: Miniaddicts.co.uk
Posted 11 November 2005 - 10:00 PM
Hi, im building a z-cars mini and i already have a servo and master cylinder from my donor car (97 cooper MPI) it it worth using it or swop for a master cylinder se-up only, Front brakes are vented KAD 4-pots, on metro discs, rear is sierra disc set-up.
What are the advantage's/disadvantages problems etc
Regards Mark :wales:
#2 Sprocket
Sprocket
    Great on Injection faults
  • 7,266 posts
Posted 11 November 2005 - 10:25 PM
Deffo servo
Unless you got realy big thighs
or you use smaller piston master cylinder.
All depends on how you want the pedal to feel as without you will have to provide the force that you narmaly use and then also that what the servo provided
#3 Puddings
Puddings
    Nurburgring Master
  • 1,046 posts
  • Local Club: fabmoc/TMF
Posted 11 November 2005 - 10:44 PM
KAD do a brake bias front to rear could be worth a look a bout half way down :lol:
#4 Sprocket
Sprocket
  • 7,266 posts
Posted 11 November 2005 - 10:55 PM
:thumbsup: Tis the way to go, you can then select the master cylinders to give you the right pedal feel you're after :cheese:
#5 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 12 November 2005 - 12:00 AM
Forget it... also to run the servo you need a source of vacuum, which has been relocated to the rear of the car.... hmmmm more piping..
Personally I'm not a fan of servo brakes on a mini, and for a car a light as a zcars all it's going to do is loose the feel of the cars handling.
#6 Wil_h
Wil_h
  • 3,244 posts
Posted 12 November 2005 - 09:56 AM
I agree with guess work.
A servo dosen't improve the braking, omly reduces the effort on the pedal.
#7 The Matt
The Matt
  • 17,231 posts
  • Name: Matt
Posted 12 November 2005 - 10:13 AM
But with it being a car that originally had a servo, how much effort will it be to remove it? Different brake pipe routing etc??
Also, think of the weight reduction by not having a servo! :lol:
There are plenty of fast motors out there that don't have a servo for the brakes, I reckon a mini stops fine without a servo (unless you find pressing the pedal really hard).
My mates Lotus Elise doesn't have a servo and that stops just fine! :wink:
#8 markrally
markrally
    Z Cars
  • 1,378 posts
Posted 12 November 2005 - 05:54 PM
KAD do a brake bias front to rear could be worth a look a bout half way down :w00t:
I like the idea of the bias padal box as i had one on my escort mk2 and it gave no trouble at all. But i think it is a bit of overkill as my mini will be used on the road mainly so i dont have a clue what it cost but i would estimate £150 upwards plus the cylinders at £25 each. I think i may just fit a new mini master cylinder but will i still need the valve assembly that is bolted to the bulkhead and can i use the one i already have or is it for the servo assembly only? That's one for guessworks???????? :w00t:
Cheers Mark :wales:
ps does anyone know how much the KAD padal box is? and will it fit my servo type pedal assembly?
#9 Jammy
Jammy
  • 25,397 posts
Posted 12 November 2005 - 06:28 PM
If your talking about the brake pressure valve then they aren't dependant on servos.
#10 markrally
markrally
    Z Cars
  • 1,378 posts
Posted 12 November 2005 - 06:38 PM
Ive just had a look on minispares and a tandem master cylinder is over £100 new so the kad pedalbox may be on the cards yet????????
Any idea on price Jammy?
#11 Jammy
Jammy
  • 25,397 posts
Posted 12 November 2005 - 06:50 PM
For a pressure valve... about £80 I believe.
#12 markrally
markrally
    Z Cars
  • 1,378 posts
Posted 12 November 2005 - 06:54 PM
No, i already got one of them along with the servo unit from my 97 cooper.
I meant the Kad pedal box, simple plumbing, no valves etc.
Mark :wales:
#13 Jammy
Jammy
  • 25,397 posts
Posted 12 November 2005 - 06:55 PM
Ah rite, erm, I'll have a look to see whether I got a pricelist with my catalogue...
#14 Jammy
Jammy
  • 25,397 posts
Posted 12 November 2005 - 06:59 PM
OK, adjustable bias pedal box - £160.38. They do master cylinders for the pedal box - £98.70. And a cable adjuster kit for the box - £33.31. All prices including VAT.
#15 markrally
markrally
    Z Cars
  • 1,378 posts
Posted 13 November 2005 - 05:21 PM
Do you know anyone with one? It doesnt look a lot too it really? If i had the measurements it would be simple to fabricate it really, well working in an aircraft factory does help!!!!!
Mark :wales:
Ps thanks for the price list
do the miglia or mini se7en boys run them???
