Roler tip rockers
Posted 28 October 2005 - 04:48 PM
Posted 28 October 2005 - 06:28 PM
Posted 28 October 2005 - 06:48 PM
Posted 29 October 2005 - 11:16 AM
Posted 29 October 2005 - 12:53 PM
Posted 29 October 2005 - 02:29 PM
As standard the ratio of the rockers is about 1.25, this does vary depending on manufacturing tollerances, but it's a nice number to work with... roller's are generally available in 1.3 and 1.5 ratios, but I'm sure I've also heard of 1.7's.
With the increase in ratio, you are increasing the valve lift, but you also increase the stress which is placed on the rocker assembly, pushrods and cam.
So taking a std MG cam profile, which has a .250" cam lift, this would translate to 0.313" valve lift at std, 0.325" with 1.3 and 0.375" with 1.5's, this obviously increases the ability to flow, both in and out of the combustion chamber. What it does not do is change the duration of the lift, nor the opening time of the valve, so you're still stuck with a 252 degree duration cam..
So using a MG metro cam with 1.3 ratio rockers, is very close to the profile offered by the Kent MD256 using std rockers, which is considered the tamest of the Kent range... Using 1.5's on a MG cam would bring you nearer the lift of a 276, but the duration increase offered by the Kent adds considerably more...
IMO, unless you don't have the equipment, time or desire to remove the engine and change the cam, then the rocker ratio is the ONLY way you are going to increase the valve lift, but, pound for pound, it's much cheaper and effective to change the cam.
Posted 29 October 2005 - 04:08 PM
Posted 30 October 2005 - 10:24 AM
Yep you can deffo get 1.7:1 roller rockers. From Minisport (IIRC).... roller's are generally available in 1.3 and 1.5 ratios, but I'm sure I've also heard of 1.7's..........
There is a certain point at which opening the valve further doesn't necessarily increase flow, they may offer maximum flow when open at say 0.4" so there is no point opening them past there (it is better to have them open for a longer time to get more air/fuel in and exhaust out).
The maximum flow rate will obviously depend on head/valve spec too.
I reckon roller rockers are a simple bolt on piece of tuning equipment that offer reasonable gains, but as GW has already said, there are alot more options when tuning a motor!
P.S. I have a set of 1.5:1 roller rockers from Minisport (I got buying fever and went and got them) but now I deem them un-necessary due to my change of cam spec as they would make the car unusable below about 3000RPM!!! I now wish to change to 1.3:1 as this will be much more usable and will be kinder to my valves
Don't buy them if you are considering further mods as it may prove to be a waste of money!
Posted 30 October 2005 - 11:32 AM
Posted 14 September 2008 - 11:57 AM
Or would it be better to fit a 1.3 ratio?
Posted 22 September 2008 - 08:20 PM
So a 1.5 ratio would be a sound fit to a standard 1275 then?
any one know the answer tho the question above? ^^^^
also if i changed my standard rockers on my 1275, to 1.5's do i have to adjust the vavle timing??
thanks for your time
James
Posted 22 September 2008 - 09:52 PM
Posted 22 September 2008 - 09:59 PM
Posted 11 May 2010 - 10:12 PM
I changed the standard rocker gear on my standard head (apart from double valve springs).
I did find that the engine did 'breathe' ever so slightly more easily but i had to fiddle with the timing and the mixture to get any real difference from it.
After a week I was fed up with the loss of low down pick up and power, constantly having to push the revs even in light traffic just to get the engine respond in any meaningful way. So I changed back to the standard rockers and I was much happier, as was my engine.
What I found more interesting is that I now have 1310cc bloc with stage 2/3 head and Kent 266 camand I tried it again. Same thing happened. I still run the standard rocker 1.3 rocker gear from my original 1275 with all the joy of low end power (2k up) with no noticeable restrictions of power or revs up to around 7000rpm in 1st, 2nd & 3rd.
#Note: my engine can rev higher but there's no power up there so I choose not to
In my personal opinion and personal experience I have found hight lift rockers to be a bit of a non-event; not quite a 'waste' of money, but I do honestly feel that the money could be better used elsewhere i.e Camshaft, headwork etc.
I do know that on much hotter bigger bore engines you would certainly see a marked improvement with high lift rocker gear.
Posted 12 May 2010 - 11:54 AM
