How to Video Guide: Removing the nose bearing race
15 replies to this topic
#1 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 22 October 2005 - 02:02 AM
For those who at anytime rebuild or replace their gearbox, there is a bearing which sits on the end of the first motion shaft, next to the input gear, which has a matching bearing race in the transfer case. It is more often than not that the bearing is broken when removing it, necessitating the replacement of both the bearing and its race.
This video how to shows an actual bearing race being removed from the transfer case. It's not magic, no mirrors are used, but I did cut the video slightly :cheese:
Enjoy.....
http://www.guess-wor...Tech/spigot.htm
Edited by Guess-Works.com, 04 February 2011 - 07:01 AM.
#2 The Matt
The Matt
  • 17,231 posts
  • Name: Matt
Posted 22 October 2005 - 05:19 PM
yet more good advice! Looks like you had some fun with the blowtorch though :wink:
#3 Sprocket
Sprocket
    Great on Injection faults
  • 7,266 posts
Posted 22 October 2005 - 08:26 PM
LOL. Having a little truble with your blow torch there :cheese:
This is similar to what we do at work to remove the centrafugal impellor off the high speed shaft. We use a temperature indicator though, heat it to the point when, you spit on it, it sizzles. Only difference is we are dealing with £10000 highly balanced components :wub: requiring a little more finesse :cheese:
what about the idler bearing, does that work with that too???
#4 Jammy
Jammy
  • 25,397 posts
Posted 22 October 2005 - 08:48 PM
Which is what spitting on it gives you! LOL! :wub: :alien:
#5 Pooky
Pooky
  • 5,691 posts
Posted 22 October 2005 - 08:51 PM
lol @ jammy :wub:
#6 Madmax
Madmax
  • 2,638 posts
  • Local Club: Grimsby & Louth MOC
Posted 24 October 2005 - 06:54 PM
anyone else think GW sounds like Bill Oddie?
:wub:
good work, hopefully the beginning of many more
#7 Tarks
Tarks
  • 727 posts
  • Local Club: is there a local club? lol
Posted 24 October 2005 - 07:13 PM
:teehee:
:wub: totally!
love the special tools needed ! just hit it! quality ! nice tip that tho gw ! :wub:
#8 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 25 October 2005 - 06:13 PM
I'm saying nothing.....
apart from...
Nope, you still need a blind bearing extractor to get that out...
#9 Pickup76
Pickup76
    Ring Runner 2005
  • 1,191 posts
Posted 26 October 2005 - 07:05 PM
ha ha LMAO, Gw did that for me when he bought my new box up and had exactly the same problem wit the blow torch, classic! Good guide though!
#10 MRA
MRA
  • 7,607 posts
Posted 05 January 2006 - 10:04 PM
apart from...
Before I had a bearing puller set, I used the following:-
A self tapper
A hammer
A pot of grease
A screwdriver
A GOOD set of safety goggles
Method:-
1.) Place transfer case clutch side down.
2.) Screw the self tapper into the drain hole - tight fit.
3.) Fill shaft hole with grease.
4.) Fit "old" idler gear gently into place.
5.) Place safety goggles over ones eyes - and any bystanders
6.) Apply sharp taps to the idler gear.
This will take a little time and is a bit messy and if you choose not to wear your safety goggles then potentially very dangerous.
But it DOES work, it works by hydraulics :smartass:
#11 Sprocket
Sprocket
  • 7,266 posts
Posted 05 January 2006 - 10:37 PM
:smartass:
Clever indeed :angry:
#12 icklemini
icklemini
  • 2,982 posts
Posted 03 February 2007 - 09:46 PM
Years ago before i got the pukka Rover tools, i used to weld an old bolt to the bearing (and the nose bearing race) to pull it out...
the heat of the weld also helped to free the grip the alloy had on the bearing.
ttfn,
Dave
#13 *DJH*
*DJH*
  • 4,972 posts
Posted 03 February 2007 - 09:57 PM
That's Another Part Of The Mini I'm Clued Up On Now, Nice Instructional Video There John ;)
That's Now Part Of My Video Collection, Cheers.
#14 d4v1dtyler
d4v1dtyler
  • 314 posts
  • Local Club: CCMA
Posted 23 March 2008 - 09:02 AM
is this video working no more?
#15 Jammy
Jammy
  • 25,397 posts
Posted 23 March 2008 - 10:24 AM
Works for me.
