Just Bought Myself A Superchager!
17 replies to this topic
#1 BoboGib
BoboGib
    RoboGimp
  • 1,579 posts
  • Local Club: SMAC
Posted 30 December 2009 - 11:22 PM
Just won this on ebay, cost me a little more than I wanted and postage is going to be a pain where the sun don't shine, but once it arrives let the engine build commence.
Supercharger
#2 myredmini
myredmini
    My Mummy Says It's OK
  • 3,211 posts
  • Name: Dan
  • Local Club: BOG MOG
Posted 30 December 2009 - 11:35 PM
Do you know it works ? it says in the description they dont know if its in working order. Good Luck with the rebuild looks great. :)
Danny.
#3 BoboGib
BoboGib
    RoboGimp
  • 1,579 posts
  • Local Club: SMAC
Posted 30 December 2009 - 11:39 PM
Took a bit of a gamble. Done a bot of research about the charger and unless the rotors are completely fubar'd there isn't much else to go wrong with them. Just bearings and seals. Which I should be able to sort.
#4 myredmini
myredmini
  • 3,211 posts
  • Name: Dan
Posted 30 December 2009 - 11:57 PM
Sounds great, Good Luck :)
#5 evansisgreat
evansisgreat
  • 1,103 posts
  • Local Club: Not yet
Posted 31 December 2009 - 12:19 AM
I'm jealous.
#6 BoboGib
BoboGib
    RoboGimp
  • 1,579 posts
  • Local Club: SMAC
Posted 31 December 2009 - 12:27 AM
Got to figure our how and where to mount it now. Do I go for suck or blow though. Still got a few pieces together for the engine build and I need to find someone that can make some custom manifolds for me once I figure out where its going.
#7 tahitigirl
tahitigirl
  • 284 posts
Posted 31 December 2009 - 08:47 AM
Also you my need a new clutch! All three people I know had superchargers fitted and all their clutches went.
#8 THE STIG
THE STIG
    Da stig says, GO GO GO
  • 2,506 posts
Posted 31 December 2009 - 09:53 AM
go blow through then can use a intercooler and no need for any custom manifolds ,just need to get hold of a metro turbo carb and plenum
modify plenum so in put at a differant angle and fit blowoff valve otherwise will over boost on idle
and all you need the is some tubing and off the shelf silicon hoses to join it all together
and a few simple mounts for charger
blow through is easy to do, easier to get set up and will give more power
and best of all will work out cheaper to do
thats why i am doing new one blow through
#9 BoboGib
BoboGib
    RoboGimp
  • 1,579 posts
  • Local Club: SMAC
Posted 31 December 2009 - 11:41 AM
Stig, you read my mind. I've got an idea of how and where to mount it, I just need to get my hands on a turbo carb a phlenum now.
#10 THE STIG
THE STIG
  • 2,506 posts
Posted 31 December 2009 - 11:47 AM
theres been a few done already
i like the set up in the white minus very neat
#11 BoboGib
BoboGib
    RoboGimp
  • 1,579 posts
  • Local Club: SMAC
Posted 31 December 2009 - 11:53 AM
Cheers for the pictures mate. Given me an idea for routing the pipework.
As for overboosting on idle, the charger I have just bought has an Electronic clutch on the pully so i'm going to see if there is anyway to wire this up so its off at idle. I'm thinking of a microswitch on the accelerator pedal somehow but i don't know how?
#12 THE STIG
THE STIG
  • 2,506 posts
Posted 31 December 2009 - 12:01 PM
easier to fit dump /blow off valve
as the supercharger that are swithable run a by pass so the engine can still draw air to run with out the super charger
air wont pass through the super charger if its not turning so unless you have a bypass wont work
Edited by THE STIG, 31 December 2009 - 12:04 PM.
#13 BoboGib
BoboGib
    RoboGimp
  • 1,579 posts
  • Local Club: SMAC
Posted 31 December 2009 - 12:04 PM
Ah, cheers for that info mate, hadn't realised that. The charger is of a Supercharger MR2.
#14 steble
steble
  • 750 posts
  • Local Club: chichester mini club
Posted 31 December 2009 - 05:14 PM
excuse me my clutch aint gone, its as strong as ever. its down to thw other twos driving i reckon ha ha
na i cheated i think my clutch was stronger to start with mg metro engine :P
anyparticular reason you went for that supercharger???
#15 BoboGib
BoboGib
    RoboGimp
  • 1,579 posts
  • Local Club: SMAC
Posted 31 December 2009 - 05:59 PM
