Best Way To Not Get Her Stolen?
Posted 19 November 2009 - 04:23 PM
thanks Dan
Posted 19 November 2009 - 04:29 PM
Posted 19 November 2009 - 04:38 PM
The weakest point will always be the windows - no matter how strong locks you fit.
Alarm... Well... Do YOU jump if you hear one!? I don't.
And most people seem to be totaly unimpressed too.
If I have to leave the Mini somewhere 'uncomfortable' for a while;
I just take the ignition coil with me
Posted 19 November 2009 - 04:43 PM
Posted 19 November 2009 - 04:49 PM
foucus st ahve been stolen they dont hang about
im just tryin to get better protection again brake in's
plastic windows?? any one know where u can get them?
Posted 19 November 2009 - 05:04 PM
There is a film that can be put on the inside of the windows that stops it being smashed in. But if you need to smash your way out it gives like a normal car window. Can't name it but I'm sure a quick Google will bring it up. Also it's not cheap from what I remember.
Posted 19 November 2009 - 05:05 PM
Posted 19 November 2009 - 05:08 PM
Few ideas. You can get a film that goes over your window that helps it from being smashed. Iv seen it on here before. You can also fit an alarm a removable steering wheel and double lock. My mate has double locks fitted to his mini van and that knocked his insurance down by £100 alone.
havent seen that window stuff will searcht hat thanks what did he do for a double lock ive started with the steering wheel now
thanks Dan
Posted 19 November 2009 - 05:16 PM
Can't you get a garage place?
I just take the ignition coil with me(a bit of a hazzle for daily use, though).
Said that because mine has a ignition cut off
Posted 19 November 2009 - 05:31 PM
Ok, that's not an option
The boot is the most secure bit but that Discarnect thingy might not protect against it being bump started - a fuel tap might be better and will also protect against the fuel line being cut to knick your juice.
Independent deadlocks would be good since Mini lock aren't, but there's always the danger they'll just do more damage.
An alarm is defo a goody to create some panic and persuade them to leg it instead.
Posted 19 November 2009 - 06:16 PM
I take the rotor arm with me, less hassle than a coil.
Posted 19 November 2009 - 06:23 PM
havent seen that window stuff will searcht hat thanks what did he do for a double lock ive started with the steering wheel nowive got a clubman gt wheel on there its only one big bolt
thanks Dan
Hi. Found this on youtube.
<object width="425" height="344"><param name="movie" value="http://www.youtube.c...></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.c...hl=en_US&fs=1&" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>
Thats the film stuff you can get.
With the double lock I'm not sure where you get them from as it was on the van when he bought it.
This is the worst pic but you can just about make out the extra lock just down from the handle on the right.
That small little spot is the extra lock. When I next see it I'll try and take some pics for you.
EDIT: Spelling.
Edited by Mini-jon, 19 November 2009 - 06:24 PM.
Posted 19 November 2009 - 07:45 PM
What about these, has anyone got one or use one? They might be a good idea to stop people trying to nick it, won't stop them breaking in though.
Linky
Ive seen these before, and seems a really good idea to me, especially with battery in locked boot.
Al
They're great, simple but effective, and you can get alternative ones from places other than Minispares (but Minispares are great!) ... like fleabay.
