Ive been reading up on types of paint - 2k & cellulose, and i am definitely swaying towards 2K but i am worried about the dangers of using it as the hardener contains isocyanate, which is extremely toxic if breathed in, and expensive spray-booths and air-fed breathing apparatus must be used.
So i am guessing this is out of the window unless anyone has any other suggestions.
I am thinking about spraying my mini wither Ultramarine, Han blue, cobalt blue or Persian indigo (though i can not find this paint anywhere). Again ideas & suggestions would be hugely appreciated - i am looking for something of a dark blue/purple so both me and my girlfriend can make use of it.
Ive purchased a spray compressor, hose & gun;
S.I.P. Hobbyair 210 1.5 HP Compressor
Motor Power -------------1.5 Horse Power (1.1KW)
Air Displacement ----------------------------- 7.0 CFM
Maximum free air delivery -----------------4.6 CFM
RPM ------------------------------------------------- 2850
Sound pressure level dB(a) @4m ----------------- 80
Sound power level LWA ---------------------------- 94
Packed Dimensions ----- 210H x 330W x 490L mm
Weight ---------------------------------------------9.5 KG
PSI -------------------------------------- adjustable 115
Its nothing professional but I picked it up second hand in good nick for £50
I have an amateur background to spraying, interior panels, fiberglass front bumper, tail flush ect, but all using can spray so this is pretty new to me. I understand the use of thinners/hardeners with certain Cellulose paints, but is the process the same - key, prime, 1200key, spray, lacquer?
thanks again, and hey, i am sure you'll all be seeing a lot more of me around the site
Jay
Edited by jaystar89, 09 November 2009 - 04:35 PM.
