Petrol - Leaded Or Unleaded?
Posted 02 October 2005 - 10:34 PM
Posted 03 October 2005 - 08:39 AM
Whatever you do dont be fooled that LRP ( which will is also being phased out ) it leaded petrol, it is not... and not 1/2 as good as std unleaded with an additive.
I believe the earliest engine fitted with an unleaded head were numbered 99HD81, anything later than that should be running unleaded.
Posted 10 February 2008 - 01:13 AM
How can I tell if my head is for leaded or unleaded exactly? I've been running it on Unleaded simply because thats what the guy who sold it to me used. What would I notice different if I should be using an additive?
Any help would be greatly appreciated.
Edited by Mayfair85, 10 February 2008 - 01:18 AM.
Guest_iansmini_*
Posted 10 February 2008 - 01:22 AM
the likelyhood is that '85 is a leaded engine, if it is the original engine, but as leaded petrol has not been available for sometime, you'll have to put unleaded in it anyway, but you will also need to use an additive.... I suggest Castrol Valve Master, out of all the ones I've tried that's the best, and the few extra pennies for the "Plus" version which has a octane booster in it will also help you cars running...
am confused by that i have an engine with the numbers 99HD1 but you both state unleaded is that correct or should on be leaded?
Posted 21 February 2008 - 01:39 AM
is it likely to be a leaded or an unleaded
any help would be greatly appreciated.
cheers charlie
Posted 21 February 2008 - 12:23 PM
Guessworks also said that he lieved that the earliest engine fitted with an unleaded head were numbered 99HD81, anything later than that should be running unleaded.
So look on the engine and see if the engine number starts with 99HD81.
Posted 21 February 2008 - 12:31 PM
chers
bm
Posted 21 February 2008 - 01:04 PM
There's no way to tell for sure your head is unleaded short of taking it off and examining the valve seats.
Posted 18 May 2008 - 07:39 PM
my engine number is 99HB81PO112799
Danny
Edited by Danny3320, 19 May 2008 - 08:54 PM.
Posted 13 June 2008 - 05:47 PM
Posted 14 June 2008 - 05:59 PM
Posted 14 June 2008 - 11:21 PM
thanks! i think if it hasnt been converted it will probs be best to have it done straight away, hopefully it will be and ill save some money...i think you have to change the head to an unleaded one. they cost around £250
Posted 14 June 2008 - 11:57 PM
if its been used even remotely in the last 10 years I'd be surprised if it hasnt already been converted.
Posted 15 June 2008 - 10:50 AM
Posted 15 June 2008 - 10:53 AM
both of mine where used as dailys by the previous owners and are still on leadedthanks! i think if it hasnt been converted it will probs be best to have it done straight away, hopefully it will be and ill save some money...i think you have to change the head to an unleaded one. they cost around £250
