Carb To Injection Supercharged
32 replies to this topic
#1 THE STIG
THE STIG
    Da stig says, GO GO GO
  • 2,506 posts
Posted 11 June 2009 - 06:13 AM
am converting mates suck through carb set up to injection for him will be good to see the differances in performance and mpg
so far collected the car last night removed the inlet tract and carb ( theses will be for sale as a complete unit ) and made up new inlet tract to take a mpi throttle body
will use 3 injecters 2 standard mpi ones ans a 3rd one from rover 220 as 3rd one will just be used to make sure there is enough fuel avalible if needed
had some injecter bosses made to hold the injectors and will be welded in where is held in pic one in front of pipe one behind on the mounting face 3rd injector will be in the bend of the inlet tract
will put up more pics as go waiting for trigger wheels etc to turn up
Edited by THE STIG, 11 June 2009 - 06:14 AM.
#2 evansisgreat
evansisgreat
  • 1,103 posts
  • Local Club: Not yet
Posted 11 June 2009 - 08:46 AM
Will be keeping a close eye on this, sounds like an interesting idea.
#3 John H
John H
  • 768 posts
Posted 11 June 2009 - 10:06 AM
What engine management system are you planning on using?
#4 apbellamy
apbellamy
  • 1,001 posts
Posted 11 June 2009 - 10:11 AM
Looks interesting.
Have you considered moving the throttle body closer to the s/c to reduce some of the problems with having the carb so far from the s/c??
#5 THE STIG
THE STIG
  • 2,506 posts
Posted 15 June 2009 - 07:26 PM
Looks interesting.
what problems ??
2 of the injectors fitted
#6 apbellamy
apbellamy
  • 1,001 posts
Posted 15 June 2009 - 07:45 PM
The air fuel mix freezing inbetween the carb and the blower. Common problem with this kind of setup
#7 THE STIG
THE STIG
  • 2,506 posts
Posted 15 June 2009 - 07:48 PM
not been a problem on my prevous two supercharged engines gets cold but never caused any issues
plus there is no carb its a throttle body air only ,the fuels going straight into the supercharer via injecters
Edited by THE STIG, 15 June 2009 - 08:23 PM.
#8 THE STIG
THE STIG
  • 2,506 posts
Posted 26 June 2009 - 06:54 PM
well all parts are here exept for peressure regulator
picked up modified bottom pully and trigger wheel today
collected mpi fuel tank and fuel lines today as well
running a megasqiurt 2 v3 ecu with edis and wasted spark coil
will start fitting everthing tomorrow and sunday
so now have for sale a standard bottom pully, swithable fuel reg and feul pump for running carb set up parts will be removed from car tomorrow £100 +p&p for all 3 items saving of about 60 over new parts have only done about 800 miles since fitted
#9 matnrach
matnrach
  • 63 posts
Posted 26 June 2009 - 10:09 PM
I suspect you may need to play a lot with the transient fuelling.
My boosted engine has injectors closer and minimal plenum volume and the transient fuelling was still very tricky to map out.
Attached File  newcamera_007small.JPG   184.37K   84 downloads
#10 MRA
MRA
  • 7,607 posts
Posted 26 June 2009 - 10:49 PM
Hey Stig,
Those injector ports look real smart, where did you get them from ? :(
If its freezing it is also making the gas / air mixture denser thus more going in :)
Regards Martin
#11 THE STIG
THE STIG
  • 2,506 posts
Posted 28 June 2009 - 06:58 PM
well today i removed charger and fitting air temp sensor and a take of for boost gauge and map sensor
also fitted bung for lamba sensor and removed fuel tank and fuel lines ready for mpi tann and fuel lines to go on tomorrow night
started to lay out wiring loom to part in engine bay
removed pully fuel pump and regulator noe in classifieds
#12 centralminimart
centralminimart
  • 17 posts
Posted 07 July 2009 - 03:34 PM
stop messing and get on with it
Edited by centralminimart, 07 July 2009 - 03:35 PM.
#13 MRA
MRA
  • 7,607 posts
Posted 07 July 2009 - 05:37 PM
Hey Martin are you giving my mate stick ??? :lol:
Regards Martin
#14 THE STIG
THE STIG
  • 2,506 posts
Posted 26 July 2009 - 06:55 AM
finnally managed to do some work on car today after being in hospital
fitted mpi fuel lines to car ,fitted adjustable pressure regulater,
fitted bottom pullt with trigger wheel
removed dizzy and fitted blanking plug
refitted exahust manifold and super charger
made fitting from temp sender exstention nut and outlet pipe flange ,welded together so that the water temp sensor fits where water tap used to be now using a metro samwich plate on thermostat housing to run the water pipr to heater
list of things to do
1 make mount for crank postion sensor
2 run wire for fuel pump to tank from ecu
3 plumb in injectors
4 run engine loom to injectors and sensors
5 fit tank and fuel filter
6 mount ecu
7 load timing and fuel map
think thats it bound to be something else though
#15 Phaeton
Phaeton
  • 1,055 posts
Posted 26 July 2009 - 07:25 AM
Stig, Slightly OT, quite bizarrely was just looking at the 36-1 on trigger-wheels, once fitted do you have to space the fan pulley out by the same thickness to keep them in-line? Assuming that's what you've used?
Alan...
