Can't wait to get the car on the rollers (if it runs!) and see what all the little modifications I've done will add up to!
I think the biggest issue with the flow on that is the bolt.
Cant you do something with it to minimise the interuption to the air flow like thin it down and knife edge it? leaving the thread on top, its not like its going to have pressure trying to bend it, only pulling on it.
Yes and no burnard.
Yes, its an interruption to the air flow but, as retro replied above, round is the best shape for that stud. And it also helps to deviate part of the air flow on the two holes on the side of the elbow (shame ive forgot their technical name).
Making the base of the stud thin but round will be an improvement, but not worth the hassle imho.
The elbow has to be smoothed with 400 grit, its the inlet that have to be 'rough', i see you already did a very good work on your inlet.
I usually do a bit more work on the throttle spindle.
I would start with AAA needle, definately not with AAC.
Dont know if you already changed it, but i'd reccomend a brand new red spring for your carb.
You'll notice a great throttle responce with that modifications, especially on full throttle, you'll be amazed by the difference.
You're doing a very good job with Reginald!
Edited by jaydee, 15 September 2009 - 02:38 PM.
