Engine spluttering and dieing when revving
Posted 01 September 2005 - 05:37 PM
Posted 01 September 2005 - 09:35 PM
Posted 01 September 2005 - 09:42 PM
is it a carb?
Posted 01 September 2005 - 10:10 PM
is there definatly fuel getting to the carb/injectors?
Posted 01 September 2005 - 10:13 PM
has this only happened recently?
i'm putting my money on throttle cable/idle adjustment
Posted 02 September 2005 - 08:23 AM
If it is not idling slowly your mixture might be a bit lean, especially if pulling the choke out keeps it going. Do you have a colourtune? If not, whip out the plugs and see what colour they are.
Posted 02 September 2005 - 08:53 AM
my throttle and choke cable were apparently too tight or something like that, after some fiddling with the carb all is okay.
Posted 02 September 2005 - 10:34 AM
It runs well when the choke is pulled out, even only a little bit so it must be getting petrol and air and the exhaust is fine.
How do I adjust the mixture on the carb? I'll try that and see if that helps.
Sorry but whats a colourtune? I doubt I've got one so I'll try and take the plugs out but I probably don't have a socket deep enough. If it's lean it will be whitish right?
The thing that threw me off is the loose accelerator pedal, will that just need tightening?
Cheers for the help
Posted 02 September 2005 - 10:40 AM
A coloutune is a spark plug type thing that you put in place of one of the spark plug and glows different colours depending on whether your mixture is rich or lean.
There will be two ways of adjusting the mixture depending on which carb you have. It will either be the HIF38 or the older HS4. Is there a float bowl on the side (like a little pot on the drivers side of the carb that the fuel line goes to)?
Posted 02 September 2005 - 10:46 AM
what speed does the car idle at with the choke out? it should be about 1100 or maybe a little bit more, if this is so then your fast idle is ok.
I'd then check a) your throttle cable
that's not right! lolthe pedal itself feels really loose, it's kinda wobbly and is really easy to puch down
B) your throttle adjusting screw
c) jet adjusting nut
Posted 02 September 2005 - 11:01 AM
Yeah I think it will be a HS4, when I'm standing infront of the mini there a cylindrical part attaching to the carb it has two tubes going into it.
I don't have a rev counter so I can't tell what the revs are when the choke is out.
Posted 02 September 2005 - 11:31 AM
One thing I forgot was whether there was any oil in the dashpot! Under the black nut on top of the dashpot and then bring the piston up and then push down, there should be some resistance when you push it dowm. If there isn't top it up with some engine oil, 3-1, or transmission oil.
I can't really recommend messing with the mixture unless its clear that the mixture is the problem. When you adjust either screw, try and remember how many times you've turned it so you can put it back to how it was if it doesn't cure the problem.
IIRC, the idle screw should be passenger side of the carb and near to the manifold (but right next to the dashpot), and screwing it inwards (down) will increase the idle speed. Run the engine til it is warm and will start without the choke, then turn the idle screw a quarter turn at a time. If you adjust it til the engine is revving quite high and its still dying then it is probably the mixture.
The mixture screw is part of the assembly that comes out the bottom of the carb. You need to screw the nut (I think its the one directly underneath the spring) in (or upwards) a quarter turn at a time. Do this until the engine will idle without dying.
Posted 02 September 2005 - 11:33 AM
Posted 02 September 2005 - 01:17 PM
I did try to start it with the choke out a tiny bit and it fired up and ran, probably would of ran all day if I'd let it but as soon as I touched the accelator it died, I tried it a few times and exactly the same thing hapened. With the choke out (about halfway maybe less) it will start up and I can rev it with the accelaror without anything happening.
I didn't risk messing with the mixture.
On a side note, will my mini take unleaded petrol? I looked in the handbook but it didn't mention it.
Posted 02 September 2005 - 01:35 PM
As to whether it is unleaded. There really isn't anyway of knowing without pulling the head off, I can't remember when they started putting unleadeded heads on minis but I think it was the late 80s.
