Fitting Hif44 Carb
Posted 07 February 2009 - 06:16 PM
On one side of the carb there are three pipes sticking out and infront of the butterfly there's another small pipe. What goes where?
I know I need fuel going in and that there coudl be a fuel overflow pipe, but not sure what the third could do, or whether I'm right about the overflow. I looked in Vizard and there is some info in the economy tuning section, but I'm not 100% on whats what.
While I'm here I might as well check what the bast way to connect the water-heated manifold up is?
So, how do I plumb it all in? I have fuel in and a vacuum advance, but four different places to plumb things.
Cheers!
Posted 07 February 2009 - 06:20 PM
1 - vacuum advance
2 - accelerator
3 - choke
4 - fuel in
5 - overflow/float vent
6 - crankcase ventilation
7 - adjustment screw
Posted 07 February 2009 - 06:21 PM
left side of carb 3 pipes.
1 at the back, 2 in middle more or less, one above the other..
1 at back fuel in, bottom middle overflow, tops just a breather.
The near the front same side, larger pipe, may be blanked off, engine breather connection.
ha ha as the picture above
Edited by lrostoke, 07 February 2009 - 09:22 PM.
Posted 07 February 2009 - 06:24 PM
Overflow thing - how would that plumb in, where does it go to?
Thank you!
Posted 07 February 2009 - 06:25 PM
Now I did a search on this after fitting same manifold and seemed a common thing
Look how thick the mounting lugs are compared to your exhaust manifold, we had to shave ours down, so that the mounting washers sat flush.
Also we found the heated pipe casting was hitting the rocker cover, even with the rocker covered pulled right foreward, stopping the manifold sitting flush against the head, we also had to shave that down.
Posted 07 February 2009 - 06:34 PM
Looks like the carb will be too high for the bonnet on the Minus, so that'll have to be jacked up a bit at the back I think, until I can afford a new bonnet with a suitable bulge.
Posted 07 February 2009 - 06:37 PM
The heatshield has a bolt sticking out of the top - whats that for? I can't see exactly how the choke cable attaches, is it anything to do with that?
Ta
Posted 07 February 2009 - 09:11 PM
At right angles to the slot is the choke cable location, its held in place by a special clip that fits in the slot..
top right of photo, can see throttle slot, and slot for special clip
http://www.minispare...ty=pb&pid=37553
oh I think that bolt is for the airfilter
Edited by lrostoke, 07 February 2009 - 09:12 PM.
Posted 07 February 2009 - 10:29 PM
Posted 07 February 2009 - 10:31 PM
Posted 16 February 2009 - 01:48 PM
I cranked the engine for about 20s to get petrol through and the little man just fired up, no questions asked! I was amazed! I've had the colortune out and adjusted from one extreme to the other - the needle is faaaaaaaar too rich! Drives ok round the drive etc while putting him back in the garage, so progress, but new needle required!
I tried to get the needle out to see what needle it is, but I couldn't, so my first question is how do you remove the needle?
I've got WinSU and that suggests I go for a BCD Needle with a Yellow spring, anyone got any thoughts on that?
The engine is an MG Metro 1275, Stage 1 exhaust, HIF44 Carb, MG Metro inlet manifold, K&N cone filter.
Cheers.
Posted 16 February 2009 - 01:54 PM
Last of the Coopers with a HIF44 had the BFY needle according to Haynes. profiles very similar to the BCD, BFY is just slightly richer.
Posted 16 February 2009 - 02:00 PM
