Twin Carb Manifold
5 replies to this topic
#1 mister bridger
mister bridger
  • 911 posts
Posted 29 December 2008 - 12:24 PM
The twin hs2 carbs I am trying to fit are mounted on a manifold with the numbers 12g299 VAF cast into them and the number 594 stamped above. It has been suggested this is not a Mini manifold - can anyone confirm this?
#2 BoboGib
BoboGib
    RoboGimp
  • 1,579 posts
  • Local Club: SMAC
Posted 29 December 2008 - 12:32 PM
the manifold you need is either,
AEG347
12G2463
AUE1014
That one you have looks far to long from the carb to the head part.
#3 mister bridger
mister bridger
  • 911 posts
Posted 29 December 2008 - 01:11 PM
that would explain why I'm having trouble fitting it in the space available! Was told it had come off a mini racer but who knows?
#4 dklawson
dklawson
  • 10,923 posts
  • Name: Doug
Posted 29 December 2008 - 01:36 PM
That number is familiar. A thread about that casting number ran earlier this month. It's an MG-1100 manifold. It will put your twin carbs in the wrong position.
See this thread on this board. Inside that thread is a link to a more comprehensive thread at Mini Mania. The Mini Mania thread is worth a read if you plan on using this manifold.
http://www.theminifo...x...6&hl=12g299
#5 mister bridger
mister bridger
  • 911 posts
Posted 29 December 2008 - 04:48 PM
Wow that was really useful - no wonder I've had such problems with these. Thanks.
#6 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 29 December 2008 - 07:33 PM
Never mind the part number, I can tell from the photo that the angle is wrong! Mini manifolds are 30 degrees, that looks like a 10 degree manifold.
If it is a 10 degree you might get away with swapping the float bowl adaptors on each carb around instead of buying new ones, since the 10 degree spacer reverses to become a 30 degree. Depends on which spacers have been used, the alloy ones and some plastic types are non-reversible but the coloured rubber ones will make the swap. That is if I'm right and it is a 10 degree setup, it might not be.
Then you just need a manifold.
Edited by Dan, 29 December 2008 - 07:36 PM.
