Hope they help.
Posted 28 October 2008 - 10:07 PM
Posted 29 October 2008 - 07:18 PM
Posted 30 October 2008 - 10:30 AM
You dont have to cut off those lugs to clear the manifold, if your making the kit, you might as well just run a single belt that does alternator, water aswell rather than use a V belt. It means you can get the charger further to the left and make everything so much easier. If you go for the Jonspeed/Vmaxx set up you will need to machine into the charger, if you use one drivebelt, you wont need to.
On mine, I've machined away all of the area in red;
Posted 30 October 2008 - 07:31 PM
Posted 31 October 2008 - 12:03 PM
Posted 31 October 2008 - 07:07 PM
Posted 20 November 2008 - 10:26 AM
Posted 18 December 2008 - 09:46 PM
Posted 20 December 2008 - 05:57 PM
Posted 16 June 2009 - 09:54 PM
Posted 19 June 2009 - 01:50 PM
You could do it with the blades still in there but it's a bit hektic. Just take the charger apart, it comes apart pretty easy.
Like zis;
Much better flowing than the Vmax/Jonspeed design.
Some food for thought.
Posted 19 June 2009 - 07:11 PM
