SPI Cooper problems
Posted 14 July 2005 - 12:21 PM
Posted 14 July 2005 - 12:29 PM
Posted 14 July 2005 - 03:35 PM
Posted 14 July 2005 - 08:42 PM
Posted 14 July 2005 - 09:00 PM
I would say there may be a fault with a sensor, if the ECU was duff then the engine wouldn't run, but if you find the MAP sensor faulty then you will have to renew the ECU as it is built in, electronics are normaly very reliable but are suceptable to moisture and voltage spikes(might be worth checking your voltage regulator on the alternator).
The ECU controls the fueling by comparing the reading from the lambda sensor, manifold vacuum (MAP)and throttle posission to its pre programed tables( this is the bit that can't be altered and where Superchips are taking advantage) after correcting air density by measuring air inlet temp, adjusts the fueling to suit. If any of these sensors are not functioning correctly then the fueling will be incorrect.
Also try powering down the ECU by unplugging it at the main connector for about 30 seconds then plug it back in and start the engine but don't rev it, let it idle for about 10 minuts for the ECU to learn the engine. Another thing I found was the K&N filters are a bugger, if you over tighten the jubalee clip it tends to pull the whole thing up after a time leaving a gap where the injector cable passes through the injector body.
Index the throttle.
Don't go and bin parts without first finding out the cause of the problem, not the symptom. Unfortunately for the ECU sensors you will have to take the car to a garage and have a diagnostics check, but even then you probibly know more about your engine than they do, so you will have to take the information ( not the mechanics opinion unless he can prove with out a doubt)and work it out yourself, like I said unfortunately you'll have to do this to get the information. I found mechanics that don't know you or the car to be a bit funny, they think you know less than them because you have taken your car to them to fix. I find this is happening more and more these days, thats why I choose to do virtualy everything myself when I can.
I found out some of this as I this week had similar problems, eratic idle, stalling on cold start idle and get this, backfiring into the inlet manifold. I found the problem to be fuel in the vacuum sensing pipe Connected to the ECU at the ECU end, this obviously was causing inacurate MAP readings. I had the whole injection system apart and found nothing else, powered the ECU down and restarted and everything's now fine.
Hope some of this may be of help.
Posted 14 July 2005 - 10:11 PM
I was reading my Haynes manual earlier and noticed that the Flywheel obviuosly has magnets attached to it but more importantly has a magnet missing at 0 and 180 degrees so the ECU knows when the engine is at TDC.......
Should the flywheel be in a certain place when it's put back on the car? it doesn't actually tell you in the manual to set the engine to TDC and put the flywheel in at a certain point, but this would seem like a fundimental thing? otherwise the ECU surely will surely get a wrong signal!
Posted 14 July 2005 - 11:22 PM
If the ECU is not connected to the manafold vacuum then this is the fault.
As for the flywheel, theyre not magnets they are high spots cast into the metal at time of manufacture. The crank possision sensor is called a Reluctor, there is a coil of wire with current passing through it, as one of those 34 high points passes the sensor the current changes giving a pulsing current that the ECU can read, the two missing high spots equate to TDC and BDC on No 1 cylinder and the ECU would see something like this ----------------- ----------------- ----------------- and so on. The sensor fits in the flywheel housing and shouldnt move, the flywheel can only go on one way located by the locating washer.
I do believe however that there is some incompatable parts around, this was extracted from the Mini Spares Center web site "Flywheel Part No. C-AEG423 - With AP pressure plate This flywheel must use a genuine AP CLUTCH PRESSURE HE3864 (GCC679)or Genuine AP clutch(our own GCK151AF)or the car WILL NOT START because the timing slot is out .USE C-AHT596 WITH CORRECT PRESSURE FOR BEST CLUTCH AVAILABLE ON VERTO MINIS this has 2 timing oval holes. Do not try to fit anything other than the genuine AP clutch and beware of Unipart supplies because under GCK151AF they are also using valeo pressures which will work " I don't realy know what they are going on about but some one on here might
I may be wrong but i thought all spi systems are the same, i'm intregued. let me know the out come as this is my own first SPI and i'm curious to know more as no dout are you
Think I should start a thread called Fuel injection explaind, though I'm no expert.
Posted 15 July 2005 - 12:19 AM
Picked it up next day running sweet, they said it had bad vaccum/ few gas leaks, they changed a few pipes n stuff, and then gave it a tune, and it still works well. They said though that it will need a few hundred miles to remove the C**p that had built up.
Then my brother goes and crashes it a few weeks later!!! :nugget: but this weekend it should be road worthy again (will just need MOT, windscreen and TAX)!
Posted 15 July 2005 - 05:58 AM
The only reason i thought SPI's and MPI's were different is because i read somewhere that MPI's have cam phase sensors which were mounted in the old fuel pump hole on the back of the block, mini doesn't have that, therefore stupid assumption that MPI's might work in a different way with a few extra sensors.... then again i may also have got the wrong end of the stick on that one.......
Posted 15 July 2005 - 06:19 AM
Rip out anything to do with the injection system and replace with a carb ! :cheese:
Only kidding, IMO, injection = voodoo black magic.
Posted 15 July 2005 - 09:50 AM
Posted 16 July 2005 - 07:55 PM
Posted 17 July 2005 - 01:18 AM
http://www.picotech....bda_sensor.html
http://www.cats-dire...ring-advice.php
Posted 17 July 2005 - 11:43 PM
Posted 18 July 2005 - 07:26 AM
