Project Student Loan+ebay= Project Ermintrude
#121
Posted 17 July 2009 - 06:06 PM
#122
Posted 19 July 2009 - 01:29 AM
#123
Posted 09 August 2009 - 04:59 PM
hope you get well soon man! Metro steering column? does that mean headlight controls on the stalks??
I have an early metro coloumn so no headlights on the stalks but nevermind. Anyways had a week off work recently so have spent the first two days in bed followed by two days in coventry but have managed to spend the last three days working hard on the mini and some good progress has been made. i will hopefully upload some photos after i have rewarded myself with some food and drink!!
#124
Posted 09 August 2009 - 05:47 PM
Edited by Fire_monkey, 09 August 2009 - 05:47 PM.
#125
Posted 09 August 2009 - 08:31 PM
Day 1.......
Engine moved to garage and given Intense clean
New timing chain tensioner
New waterpump
Diff rebuilt and refitted using new gaskets
New thermostat and housing
New heater hose takeoff and gasket
new gaskets and washers for the oil filter housing and pipe
fuel pump gasket and blanking plate fitted.
Rollcage refitted using new stainless steel securing plates and all new bolts and then sealed using sealent and custom gaskets under each leg to ensure a total seal between the cage and the car.
Day 2........
Pedal box refitted followed by the steering coloumn and then drivers seat positioned and fitted using high tensile bolts with spreader plates through the floor.
Passenger seat then fitted in the same method.
For a bit of relaxation the eye bolts and harnesses where then put in and then fitted to me.
New timing chain cover gasket installed and then cover refitted and pulley drive and fan fitted. Decision made to buy a whole new clutch for piece of mind while the engine is out of the car.
New clutch slave cylinder and braided line fitted.
Engine put fully back together and lifting straps secured in place ready for fitting.
Lifting frame built out of thick scaffolding bar across drive and then lifting tackle secured onto cross bar ready for engine install tomorrow.
Day 3........
Engine in
Engine out
Engine in
Engine out
Engine in properly
Not a good day so far
Drivers side engine stabiliser in
Passinger side stabiliser in
starter motor on
Alternator on
Brake master cylinder bracket on
exhaust manifold and system on
Radiator and cowl on
Radiator pipes on
All front end bolts tightened and secured with driveshafts being fitted into the diff.
I may have missed a few details but its been quite a few intensely hot days.
Now you have been patient enough to read my babble i will let the pictures to do the talking.
rollcage plates
P1010224.JPG 154.45K 11 downloads
pedal box
P1010222.JPG 164.16K 15 downloads
seats and harnesses
P1010223.JPG 176.74K 51 downloads
steering coloumn and gearchange
P1010226.JPG 176.37K 30 downloads
under exhaust
P1010230.JPG 157.17K 9 downloads
engine in and being built up
P1010220.JPG 147.61K 37 downloads
P1010221.JPG 215.69K 90 downloads
P1010227.JPG 140.92K 31 downloads
P1010228.JPG 161.08K 24 downloads
P1010229.JPG 170.68K 32 downloads
Thats it for now and its back to work tomorrow but i will get on it as soon as i can.
#126
Posted 10 August 2009 - 11:45 AM
loving the engine bay and colour coding!
i have a webber now for the mk2 im building with my dad! you should check out the project page! could even be better than the bean when its done.... lol
(its in complete mini rebuild )
#127
Posted 18 August 2009 - 03:27 PM
finished changing and mounting the headlights and changing them from sealed beams to halogens.
been working on using brass bulkhead pipe fittings instead of having a gromet throught the bulkhead for the heater hoses
Found part of an old pneumatic setup which may work well as a catch tank for the oil.
P1010231.JPG 78.98K 8 downloads
P1010232.JPG 77.02K 14 downloads
P1010233.JPG 80.81K 32 downloads
P1010234.JPG 72.81K 14 downloads
thats all for now but hopefully will get a day off soon.
#128
Posted 20 August 2009 - 04:39 PM
Made a few brackets for the radiator out of some 3mm ally.
Bulkhead heater fittings in along with pipes. although need to add some more right angle joints to the top hose to bring it down under the bonnet.
P1010235.JPG 77.57K 8 downloads
P1010236.JPG 80.85K 18 downloads
P1010237.JPG 88.74K 18 downloads
T
#129
Posted 21 August 2009 - 02:55 PM
#130
Posted 21 August 2009 - 06:36 PM
liking the brass fittings!
#131
Posted 22 August 2009 - 12:28 AM
verry nice job you have done
#132
Posted 22 August 2009 - 07:41 AM
Really liking your pedal box where did you find it from?
Keep up the good work
#133
Posted 25 August 2009 - 03:04 PM
in reply the pedal box i believe is the origional from the car that i have just rebuily and resprayed and then changed the pedals for some slightly larger shinyer ones.
Update time.....
Radiator brackets bent, drilled and now fitted so that's all now secure.
P1010238.JPG 74.85K 7 downloads
Brake master cylinder and coil back in along with air duct and started the wiring while trying to keep it relatively tidy and hidden away.
P1010239.JPG 87.2K 17 downloads
Cibies and brackets finally on and all measured and angled properly.
P1010240.JPG 83.33K 18 downloads
Dash drilled and mounted in place ready to measure reach distance of me so that final switch placement can be allocated.
P1010241.JPG 72.96K 22 downloads
Thats all for now
T
#134
Posted 25 August 2009 - 04:39 PM
the dash looks good mounted forward off the top rail like that! genius!
what grill are you going for?
#135
Posted 28 August 2009 - 02:48 PM
[/quote]
I am still currently undecided upon the grill as i have been given a later type one with the surround and bonnet lip but im thinking something a bit more custom and unique is required but still sticking to a classic design.
t
