Z-cars Monte Carlo, Intercooled Hayabusa Turbo, Usa Edition
380 replies to this topic
#256 irishdude
irishdude
  • 124 posts
Posted 27 April 2009 - 05:51 PM
Im still in........ :D
Any updates, haven't heard from you in a while
#257 cptkirk
cptkirk
  • 1,799 posts
  • Local Club: B.M.C. + Chiminiclub
Posted 29 April 2009 - 11:28 AM
In for an update
#258 Monte Busa
Monte Busa
  • 681 posts
Posted 12 July 2009 - 10:52 PM
Been working on the rear wing installation - will finish up the rear diffuser and floor next.
Attached File  wing_front.JPG   263K   86 downloads
Attached File  wing_side.JPG   290.68K   112 downloads
Attached File  wing_rear.JPG   232.71K   85 downloads
Attached File  wing_side_closeup.JPG   207.85K   64 downloads
#259 Saxo-Fiesta-Mini
Saxo-Fiesta-Mini
  • 2,889 posts
  • Local Club: LCMOC
Posted 12 July 2009 - 10:54 PM
AHHAHAHAHAHAHA awesome i just nearly died when i saw that wing
#260 Monte Busa
Monte Busa
  • 681 posts
Posted 13 July 2009 - 12:59 AM
yeah, it's big - 16" section width by 65inches wide - very light though - the whole thing (Carbon composite with honeycomb core) weighs less than 10lbs without the mountings...the side plates haven't been installed yet, but with them I should get close to 350kgs downforce at 100MPH when properly tuned. With the rear diffuser and front splitter / flat floor with rearward rake, I am targetting 600kgs or so downforce at 100MPH.
Fun stuff
#261 mighty mini jack
mighty mini jack
    Mighty Before a Pint
  • 5,095 posts
Posted 13 July 2009 - 01:23 PM
Really like that wing, should serve a good purpose!
#262 sotiris
sotiris
  • 127 posts
Posted 16 July 2009 - 01:51 PM
i order a b-king 1340 2008 ... same with busa i think...
how many hp this engine can be without change the internals..... (pistons and robs.....)
i have a td05h 20g mitsu turbo 440hp.....
but i am thinking to put on and run with 0.5 bar, can this engine hold.......???
maybe 250hp
Edited by sotiris, 16 July 2009 - 01:52 PM.
#263 Monte Busa
Monte Busa
  • 681 posts
Posted 16 July 2009 - 02:36 PM
If you do more than 5lbs boost, you'll want to lower the compression and swap out the rods for some forged peices at a minimum. Anything above about 215BHP will necessitate a rod swap. The engine builders I've spoken to suggest upgraded rods for even mildly tuned street engines. Another area that should be addressed is increasing the oil flow capacity via the oil pump gear change and swapping out a higher capacity pressure regulator. For even higher outputs, you may want to consider swapping out higher grade gear selector rods and output shaft as well, and possibly going to a mechanical cam chain tensioner.
maybe 250hp
#264 sotiris
sotiris
  • 127 posts
Posted 16 July 2009 - 04:04 PM
i think that for the beggining is to much to do this........
i will find more info for stage 1 turbo busa and maybe i will do it the next year.......
i will ask you about..........
thanks....
#265 Monte Busa
Monte Busa
  • 681 posts
Posted 19 July 2009 - 06:18 PM
...made a bit more progress this weekend - receiving and installing the C/F wing endplates from my man Mike Devins. I also finished the mods to, and trial fitted the Carbon Weezel rear diffuser - looks very purposeful I thnk!
Attached File  DSC00009.JPG   266.28K   98 downloads
Attached File  DSC00010.JPG   451.79K   98 downloads
Attached File  DSC00012.JPG   421.19K   93 downloads
Attached File  DSC00011.JPG   438.57K   80 downloads
Attached File  DSC00013.JPG   435.45K   65 downloads
Attached File  DSC00014.JPG   396.93K   184 downloads
#266 PhotoguyUSA
PhotoguyUSA
  • 312 posts
  • Local Club: MOALA
Posted 19 July 2009 - 07:28 PM
Love it Monte Busa!
#267 monster_mini
monster_mini
  • 981 posts
Posted 19 July 2009 - 08:08 PM
thats rear diffuser is needed on hamiltons f1 car :w00t:
#268 danny1
danny1
    In the navy you can sail 7 peas
  • 1,321 posts
  • Local Club: bumpstart
Posted 25 July 2009 - 11:15 PM
holy poop thats no mini its a space rocket hes building ahaha
#269 irishdude
irishdude
  • 124 posts
Posted 26 July 2009 - 01:35 AM
Dude your car is amazing.. That wing is ridiculous but I love it :) Just be sure you don't mount the wing the wrong way up or else you launch to the moon >_<
you probably said this already but are you stroking the engine or keeping it the same displacement. Have started on my Hayabusa research and looking into the pros and cons of different set-ups.
#270 Monte Busa
Monte Busa
  • 681 posts
Posted 27 July 2009 - 04:13 AM
I'm keeping stock displacement for now, upgrading the bottom end obviously though. I may do a small amount of head work (unshrowding valves only), but other than the intake / exhaust cam swap, the Hayabusa doesn't really need work done for turbo applications, and off-throttle response tends to suffer with larger valved engines / ported heads / too high lift from what've I've gleaned from a few experts. I am on the fence whether or not to do the engine work myself at this pt - if I don't I'm going ot have Mike Downs from Downs Engineering (who is in your neck of the woods) do the work - he's built literally 100s of N/A and turbo Hayabusa for car applications (mostly SCCA sports racers) over the years....
Dude your car is amazing.. That wing is ridiculous but I love it :lol: Just be sure you don't mount the wing the wrong way up or else you launch to the moon :ermm:
    Google (1)
