Mini Sounds Like Its Got Striaght Cut Gears
Posted 20 May 2011 - 05:33 PM
the problem is when driving along at 30ish it makes a noise like it has striaght cuts, the gearbox was rebuilt 10,000miles ago and the drop gears and bearings are only 1700miles old, now my dad reckons that the idle bearings are shot at and thats whats making the noise and the upratedness of the engine has caused them to wear quickly. i will admit i do drive it quite hard but surly the bearings should last longer that that?
to the clever folk of tmf please help
Posted 20 May 2011 - 05:40 PM
If you are hard on the clutch then the idler bearings will fail quicker
Posted 20 May 2011 - 05:43 PM
Posted 20 May 2011 - 06:05 PM
Posted 20 May 2011 - 06:17 PM
whats the best way to fix it and prevent it happening again?
Posted 20 May 2011 - 06:26 PM
An orange diaphragm on it's own will not harm the idler bearings, it's more likely to be the initial set up and shimming, and or driving style...
The engine spec' would give me no cause for concern relating to longevity of idler bearings ( or gears ), oh and as you're wheel spinning in third, I'd check your diff pin while you have the engine out.
Edited by Guess-Works.com, 20 May 2011 - 06:26 PM.
Posted 20 May 2011 - 06:46 PM
couple of other quick ones, is it possible to reshim the idler gear without splitting the engine from the gearbox?
is it worth upgrading to a 4 pin diff if so which one?
Posted 20 May 2011 - 07:34 PM
Edited by bmcecosse, 20 May 2011 - 07:35 PM.
Posted 20 May 2011 - 07:47 PM
Posted 20 May 2011 - 08:50 PM
how do i measure the clearances with the engine still on the box?
Posted 21 May 2011 - 05:23 PM
also does anybody know were i could buy the special tool for removing the idler bearings?
Posted 21 May 2011 - 06:17 PM
This sounds like it's probably what's gone on mine. It sounds horrendously loud, gearbox-wise, a kind of rattling/whining noise. Luckily, i've got a spare gearbox and transfer case in the shape of a spare 998 engine and box.
Good luck chap
Posted 22 May 2011 - 02:10 PM
Posted 22 May 2011 - 02:54 PM
Posted 22 May 2011 - 04:20 PM
